.NET
Active Contributor
giskumar
Message 1 of 5 (566 Views)
AutoCad2010 with Visualstudio-2008 (c#)
566 Views, 4 Replies
04-26-2012 04:17 AM
Hi All,
I tried to write a simple program in c#.net for autocad 2010.
I build and loaded the .dll file but not able to access the command.
When i type tst in command prompt, it prompting unknown command.
Please help  me how to solve this.
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using System.Windows.Forms;
using System.Data.OleDb;
using System.Data;
namespace AcadGlobles
    class Commands
        [CommandMethod("tst")]
        static public void test()
            MessageBox.Show("hi");
Kumar.
Moderator
Alexander.Rivilis
Message 2 of 5 (558 Views)
Re: AutoCad2010 with Visualstudio-2008 (c#)
04-26-2012 05:08 AM in reply to: giskumar
It is look like you do not assign Copy Local to False for AutoCAD DLL references in your solution (acmgd.dll, acdbmdg.dll, etc.)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Jeff_M
Message 3 of 5 (549 Views)
04-26-2012 06:34 AM in reply to: giskumar
The class Commands needs to be public. Not sure if it matters, but normally the public is the first item listed, so instead of
it woul be
public static void test()
ADN Support Specialist
augusto.goncalves
Message 4 of 5 (539 Views)
04-26-2012 08:32 AM in reply to: giskumar
Like Jeff said, the method and the class must be public, otherwise AutoCAD will not locate the method
class Commands
should be replaced with
public class Commands
Augusto Goncalves
Autodesk Developer Network
Active Contributor
giskumar
Message 5 of 5 (515 Views)
04-26-2012 09:30 PM in reply to: giskumar
Hi All,
Thanks for the reply.
Adding Public before class is working for me.
Kumar.
You are not logged in.
Ask the Community
