• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    AutoCAD assemblies copy to my Release folder
    88 Views, 3 Replies
    03-28-2012 12:21 AM
    from one moment, AutoCAD assemblies are copied to my release folder.
    It's a solution with 4 projects, all references have CopyLocal=False. Only one project has those 3 other projects referenced with CopyLocal=True. But still i have AutoCAD assemblies in that release folder.
    ManagedMC3.dll
    AcCui.dll
    AcDx.dll
    AcDxPublishUi.dll
    AcMNUParser.dll
    AcMr.dll
    AcTcMgd.dll
    AcWelcomeScreen.dll
    AcWindows.dll
    AdWindows.dll
    It used to work fine, and I'm not aware of any change that could cause this.
    One more observation: None of those 3 projects have those assemblies in their Relase folders, only the one that references them with CopyLocal=True.
    Please use plain text.
    *Expert Elite*
    Re: AutoCAD assemblies copy to my Release folder
    03-28-2012 02:24 AM in reply to: matus.brlit
    what is the reason that this one project has set the CopyLocal to TRUE? IMHO that should be never necessary.
    If you erase manually the content of the output-directory and do then a rebuild, project by project ==> look when these DLL's are created.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    03-28-2012 02:46 AM in reply to: alfred.neswadba
    The first reason was, that when i deploy the assemblies, i don't have to search all that directories, they are all put in one directory from where i take them.
    But then I found out, that I need them in one folder for debugging purposes, so I don't have to change my netload statements and the dlls are just loaded from the working directory, which is the Debug directory of the main project.
    The redundant dlls are created when i build the main project.
    03-28-2012 04:56 AM in reply to: matus.brlit
    so I removed the references and added them again, that solved it
