.NET
arcticad
Message 11 of 17 (278 Views)
Re: AutoCAD Commands from vb.net 2010
03-26-2012 10:46 AM in reply to: vbNinja
Add these lines to the top of the class
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Colors
and add the reference to
acdbmgr.dll
acmgd.dll
and set copy local to false.
(defun botsbuildbots() (botsbuildbots))
Valued Mentor
Mike.Wohletz
Message 12 of 17 (275 Views)
03-26-2012 10:47 AM in reply to: vbNinja
What  namespaces have you imported? Is this a standalone EXE application?
arcticad
Message 13 of 17 (271 Views)
03-26-2012 10:50 AM in reply to: Mike.Wohletz
the above code won't work for a stand alone exe.
vbNinja
Message 14 of 17 (264 Views)
03-26-2012 11:13 AM in reply to: Mike.Wohletz
Hi
I have the following imports:
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
And yes this is a standalone EXE Application
vbNinja
Message 15 of 17 (263 Views)
03-26-2012 11:14 AM in reply to: Mike.Wohletz
Hi
Imports System
And yes this is a standalone EXE application
Valued Mentor
Mike.Wohletz
Message 16 of 17 (244 Views)
03-27-2012 06:04 AM in reply to: vbNinja
Try something like this to set the layer colors:
    Private Sub WorkingWithAutoCAD()
        ' we can set the color of one layer or current by:
        acSetLayerColor(AcColor.acYellow)
        'or
        'set them all to green
        For Each oLayer As AcadLayer In ThisApplication.ActiveDocument.Layers
            acSetLayerColor(AcColor.acGreen, oLayer)
        Next
        ' or set the OB layer to red and see if it happened calling by name
        Dim Rval As Boolean = acSetLayerColorByName(AcColor.acRed, "OB")
    End Sub
    Private Function acSetLayerColor(ByVal oColor As AcColor, Optional ByVal oLayer As AcadLayer = Nothing) As Boolean
        Try
            If oLayer Is Nothing Then 'we will look at the current layer
                oLayer = ThisApplication.ActiveDocument.ActiveLayer
            End If
            oLayer.color = oColor
            Return True
        Catch ex As Exception
            Return False
        End Try
    End Function
    Private Function acSetLayerColorByName(ByVal oColor As AcColor, ByVal oLayerName As String) As Boolean
        Try
            Dim oLayer As AcadLayer = ThisApplication.ActiveDocument.Layers.Item(oLayerName)
            Return True
            Return False
        End Try
    End Function
vbNinja
Message 17 of 17 (235 Views)
03-27-2012 10:01 AM in reply to: Mike.Wohletz
Hi
Your suggestions worked after I added a reference to acdbmgd.dll and acdmgd.dll and imported these namespaces:
Thank you all for your help.
Best regards
You are not logged in.
Ask the Community
