• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    arcticad
    Re: AutoCAD Commands from vb.net 2010
    03-26-2012 10:46 AM in reply to: vbNinja
    Add these lines to the top of the class
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.Colors
    and add the reference to
    acdbmgr.dll
    acmgd.dll
    and set copy local to false.
    “We don’t have a snowball’s chance in a blast furnace of surviving this attack unless every one of our units gets into the fight right now!”
    Please use plain text.
    Valued Mentor
    Mike.Wohletz
    03-26-2012 10:47 AM in reply to: vbNinja
    What  namespaces have you imported? Is this a standalone EXE application?
    arcticad
    03-26-2012 10:50 AM in reply to: Mike.Wohletz
    the above code won't work for a stand alone exe.
    03-26-2012 11:13 AM in reply to: Mike.Wohletz
    Hi
    I have the following imports:
    Imports System
    Imports System.Runtime.InteropServices
    Imports Autodesk.AutoCAD.Interop
    And yes this is a standalone EXE Application
    03-26-2012 11:14 AM in reply to: Mike.Wohletz
    Hi
    Imports System
    And yes this is a standalone EXE application
    Valued Mentor
    Mike.Wohletz
    03-27-2012 06:04 AM in reply to: vbNinja
    Try something like this to set the layer colors:
        Private Sub WorkingWithAutoCAD()
            ' we can set the color of one layer or current by:
            acSetLayerColor(AcColor.acYellow)
            'or
            'set them all to green
            For Each oLayer As AcadLayer In ThisApplication.ActiveDocument.Layers
                acSetLayerColor(AcColor.acGreen, oLayer)
            Next
            ' or set the OB layer to red and see if it happened calling by name
            Dim Rval As Boolean = acSetLayerColorByName(AcColor.acRed, "OB")
        End Sub
        Private Function acSetLayerColor(ByVal oColor As AcColor, Optional ByVal oLayer As AcadLayer = Nothing) As Boolean
            Try
                If oLayer Is Nothing Then 'we will look at the current layer
                    oLayer = ThisApplication.ActiveDocument.ActiveLayer
                End If
                oLayer.color = oColor
                Return True
            Catch ex As Exception
                Return False
            End Try
        End Function
        Private Function acSetLayerColorByName(ByVal oColor As AcColor, ByVal oLayerName As String) As Boolean
            Try
                Dim oLayer As AcadLayer = ThisApplication.ActiveDocument.Layers.Item(oLayerName)
                Return True
                Return False
            End Try
        End Function
    03-27-2012 10:01 AM in reply to: Mike.Wohletz
    Hi
    Your suggestions worked after I added a reference to acdbmgd.dll and acdmgd.dll and imported these namespaces:
    Thank you all for your help.
    Best regards
