.NET
vbNinja
Message 1 of 17 (804 Views)
AutoCAD Commands from vb.net 2010
804 Views, 16 Replies
03-22-2012 10:12 AM
Hi
Recently I managed to connect to AutoCAD 2012 through vb.net 2010 and send simple commands like this:
Dim acaddoc As AcadDocument = acApp.ActiveDocument
Dim pt1(2) As Double
Dim pt2(2) As Double
pt1(0) = 3
pt1(1) = 6
pt1(2) = 0
pt2(0) = 1
pt2(1) = 5
pt2(2) = 0
acaddoc.ModelSpace.AddLine(pt1, pt2)
 I need to use more commands  to create a new layer, set a specific layer as active, select a layer's color, select current drawing color,use hatch, select linetype and lineweight. is there a way to perform the previous operations using a code that is similar to the one above?
chiefbraincloud
Message 2 of 17 (784 Views)
Re: AutoCAD Commands from vb.net 2010
03-22-2012 02:40 PM in reply to: vbNinja
Short answer, yes.
to create the Hatch, you just call AddHatch the same way you called AddLine.
The AcadHatch object returned from that has Layer, Linetype, Lineweight properties (among others).
You access the collection of layers with acaddoc.Database.Layers which returns an object of AcadLayers, which has an Add method.
acaddoc.GetVariable/SetVariable will get or set the value of AutoCAD system variables, such as CLAYER for the name of the current layer, or CECOLOR is the Current Entity Color.
Chew that up and spit it out, then come back if you have more questions.
vbNinja
Message 3 of 17 (760 Views)
03-24-2012 10:09 AM in reply to: chiefbraincloud
Hi
Sorry for being late but I've been busy the last couple of days, but I have a aquestion
the acaddoc.SetVariable function takes two parameters: Name as string, Value as object
how to use those parameters to perform tasks such as setting a layer as active or changing the layer's color?
vbNinja
Message 4 of 17 (740 Views)
03-25-2012 08:42 AM in reply to: vbNinja
Hi
I tried to use GetVariable func tion like this:
Dim acdoc As AcadDocument = acApp.ActiveDocument
MsgBox(acaddoc.GetVariable("CECOLOR"))
And the result is a message box saying: BYLAYER
so I tried reversing this by trying the following:
acaddoc.SetVariable("CECOLOR", Common.AcColor.acByLayer)
the result is an exception saying: "Error setting system variable"
and I tried many other AutoCAD variables, the getvariable works but the setvariable doesn't. what is wrong?
Valued Mentor
Mike.Wohletz
Message 5 of 17 (734 Views)
03-25-2012 10:18 AM in reply to: vbNinja
The acByLayer is the same as 256 and the help says that you can use 1 to 255. You can set this with a string and make things simple by using "YELLOW", "BLUE", BLACK", "BYLAYER", "BYBLOCK", etc.
Try this:
acaddoc.SetVariable("CECOLOR", "BYLAYER")
vbNinja
Message 6 of 17 (732 Views)
03-25-2012 10:30 AM in reply to: Mike.Wohletz
Hi
It worked! thank you so much, I have another question please: How to change the layer's color after adding it? because I don't want to change the CEColor each time I change the current layer.
Valued Mentor
KerryBrown
Message 7 of 17 (721 Views)
03-25-2012 08:28 PM in reply to: vbNinja
vbNinja wrote:
Hi
You may need to re-state the question.
I'm not sure that you will want to change the color of the layer, because that will affect everything that is drawn on that layer that is not explicitly by color  ... do you mean 'change the color of the entity' instead,
class keyThumper<T> : Lazy<T>;      another  Swamper
vbNinja
Message 8 of 17 (715 Views)
03-25-2012 09:58 PM in reply to: KerryBrown
No, I want to change the color of the layer itself, I need this for specific layers, not all of them.
Valued Mentor
AubelecBE
Message 9 of 17 (703 Views)
03-26-2012 03:36 AM in reply to: vbNinja
He here a function :
Public Function CreationCalque(ByVal NomCalque As String, Optional ByVal CB As Integer = 256, _
                                                      Optional ByVal CR As Integer = 256, _
                                                      Optional ByVal CV As Integer = 256) As String
        Dim strReturn As String = ""
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim LayerT As LayerTable 'coll des Def des calques
        Dim Layer As LayerTableRecord
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Try
            LayerT = tr.GetObject(db.LayerTableId, OpenMode.ForRead)
            If LayerT.Has(NomCalque) = False Then
                Layer = New LayerTableRecord
                Layer.Name = NomCalque
                Layer.Color = Color.FromRgb(CR, CV, CB)
                'OpenMode.Write
                LayerT.UpgradeOpen()
                'ajout à la base des layers
                LayerT.Add(Layer)
                'transaction
                tr.AddNewlyCreatedDBObject(Layer, True)
            Else
                Layer = tr.GetObject(LayerT.Item(NomCalque), OpenMode.ForWrite)
                'maJ Color
            End If
            strReturn = Layer.Name
        Catch ex As Exception
            MsgBox(ex.ToString, vbOKOnly, "Error CreationCalque")
        Finally
            tr.Commit()
            tr.Dispose()
        End Try
        Return strReturn
    End Function
 This function check if the name Layer is found otherwise it create a layer with the name pass in the function.
You need : A name of layer + code color example :
if CreationCalque("NameCalque",255,0,0) <> "" then
  ' calc Ok and Color applied"
end if.
vbNinja
Message 10 of 17 (680 Views)
03-26-2012 10:41 AM in reply to: AubelecBE
Hi
This image tells what happened
so is there any missing imports?
You are not logged in.
Ask the Community
