AutoCAD 2007 plugin compatibil​ity issue in .net framework 4
I have created a plugin for AUTOCAD 2007 in .net framework 2 and it was working properly. Now i have changed the framework to 4.0 and the plugin is not displaying in the autocad 2007.  Is there any compatibility issue with the framework version for autocad 2007? please help me in this regard....
As far as I'm aware, you can't use v4 with AutoCAD 2007.
you wiil not be able to use 4.0 until 2012
Could you please tell me which version of framework is then supported by autocad 2007
Sorry my previous statement was not exactly correct.
I think the 2007 acmgd etc..... were built with 2.0
You should be able to use later version as long as you do not use or reference any components of that later version.
