.NET
Attributes in XRef
16 REPLIES 16
Message 1 of 17
Amremad
1026 Views, 16 Replies
Attributes in XRef
hi every one
is there a way to edit the any text in xref drawing locally .
i mean if i xref DWG1 to many drawing and DWG1 have text or text attribute . can i change this texts or attributes to different value for each drawings and with saving DWG1 values .
i hope you understand me
16 REPLIES 16
Message 2 of 17
Alfred.NESWADBA
in reply to: Amremad
I'm not sure to understand the question, let me try to describe that with my words:
If you have a drawing file called DWG1 with a text/attribute like "Project-Name" set to "MY FIRST PROJECT" all drawings that uses that DWG1 as XRef will see the wording "MY FIRST PROJECT".
If you now change the label to "MY SECOND PROJECT" within DWG1 all drawings having this files referenced will see then "MY SECOND PROJECT".
Is that what you were asking for?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 17
Amremad
in reply to: Alfred.NESWADBA
thank you MR.alfred
yes some thing like field , but DWG1 have this field and i can change this field in all other drawings with different values manually not automatically :
Message 4 of 17
Amremad
see if DWG1 have a field that show me the file name of drawing ,
so this field value will change in every drawings that have xref from DWG1.
understand me?
Message 5 of 17
Alfred.NESWADBA
can you attach a sample and describe which element should be changed?
Are you speaking now about a text-object, a mtext, an attribute within a blockreference or a field-object?
- alfred -
Alfred NESWADBA
Message 6 of 17
Amremad
please download this zip file Xref Sample
i sent 5 drawing one of them called DWG1 . have 6 text object
and other 4 drawings (with different filename) have xref of DWG1.
now i need to change XX000-020XX to no of file name
i hope understand me
Message 7 of 17
Alfred.NESWADBA
does the attached file DWG1 answer your question? (I created a FIELD-object and used "document name" as property).
Exchange your DWG1.dwg with my uploaded version and open the files that use that as XRef.
- alfred -
Alfred NESWADBA
Message 8 of 17
Amremad
yes i know this way
i nead value change by me not by autocad .
ex. if i will need value other than filename . may be the name of emplayee.(not windows user)
see this attached  Xref Sample
the designed by that mean
Message 9 of 17
Alfred.NESWADBA
If it's not a field, then you can change the content of the DWG1.dwg (using e.g. _REFEDIT or, with dotNET scan through the block definitions, find the one that is the XRef and open the database then for getting access to the object within the XRef).
But this modification is then constant for all drawings which reference that DWG1, so if you open your XX001-02001.dwg, modify the value in the XRef to "AAA" all other drawings referencing this file will see "AAA" (as XRef's are working).
- alfred -
Alfred NESWADBA
Message 10 of 17
Amremad
no no .
i need to change the contents in one of subdrawing not in DWG1.
i nead DWG1 no change will be on it , just if i need to change the contents in subdrawing i can do that . understand ,
iam searching for any way to help me to do that
Message 11 of 17
Amremad
you know block attribute ?? , i can change the value of each reference blocks with diffrent value but the base block no change in it happen,
i need apply this way with Xref drawings
changing must be manually not automaticlly like field
sorry for my english
Message 12 of 17
Alfred.NESWADBA
No, that is what I tried to describe, that is not possible with XRef.
- alfre d-
Alfred NESWADBA
Message 13 of 17
Amremad
that 's my problem 🙂
any way iam trying to find any way to do what i need
Message 14 of 17
Alfred.NESWADBA
Why do you need that as XRef when this technology is not working?
If it's just the option to have other content of DWG1 distributed into other drawings then you might use _INSERT instead of _XREF and develop a tool that updates the content from DWG1 into the inserted block-definition.
Or is there another reason for needing DWG1 as XRef?
- alfred -
Alfred NESWADBA
Message 15 of 17
Amremad
i need to make frame for all drawings that have no. of drawing and some information for sheets and date and revisions then use this drawing as Xref in all drawing in my project . then change in every drawing the information for each drawing.
Message 16 of 17
Alfred.NESWADBA
well, my preferred solution would be to use the XRef for all constant parts plus an additional blockreference within each drawing for attributes/individual parts.
But the way for updating an internal blockreference from an external drawing file is an option too.
- alfred -
Alfred NESWADBA
Message 17 of 17
Amremad
yes i do this is already , but i was searching for way instead copy attribure blocks in each drawing ( can put it in DWG1 only) 🙂
thank you very much for help
”Boost
