.NET
Hallex
Message 11 of 36 (310 Views)
Re: Attribute to move to block without the old ATT
09-13-2012 08:08 AM in reply to: heinz.dober
Well,
I haven't have this version on my machine,
but I will try to rewrite the code without using Interop later,
no warrantee though,
~'J'~
Active Contributor
heinz.dober
Message 12 of 36 (309 Views)
09-13-2012 08:52 AM in reply to: Hallex
Thank you
If that would not be possible, I prefer to Lisp, a little?
Ich danke Ihnen
Wäre das in Lisp nicht möglich?
DH
Hallex
Message 13 of 36 (307 Views)
09-13-2012 09:07 AM in reply to: heinz.dober
Try this code instead, but you have to invoke command ATTSYNC
manually after:
        //        #region "System"
        //using System;
        //using System.IO;
        //using System.Collections.Generic;
        //using System.Text;
        //using System.Reflection;
        //      #endregion
        //        #region "AutoCAD Imports"
        //using Autodesk.AutoCAD.Runtime;
        //using Autodesk.AutoCAD.ApplicationServices;
        //using Autodesk.AutoCAD.DatabaseServices;
        //using Autodesk.AutoCAD.Geometry;
        //using Autodesk.AutoCAD.EditorInput;
        //using Autodesk.AutoCAD.Colors;
        //      #endregion
        // import accoremgd.dll
        [CommandMethod("nea")]
        public static void AddNewAtt()
            string blkName = "PART";
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead, false);
                if (!bt.Has(blkName))
                    ed.WriteMessage("\nBlock definition TEST does not  exist");
                    return;
                double dx = new double();
                double dy = new double();
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[blkName], OpenMode.ForRead, false);
                int cnt = 0;
                AttributeDefinition matchAtt = new AttributeDefinition();
                foreach (ObjectId adefId in btr)
                    DBObject attObj = (DBObject)tr.GetObject(adefId, OpenMode.ForRead, false);
                    if (attObj.GetRXClass().Name == "AcDbAttributeDefinition")
                        AttributeDefinition attObjDef = attObj as AttributeDefinition;
                        if (cnt == 0)
                            matchAtt = attObjDef;
                            dx = matchAtt.Position.X;
                            dy = matchAtt.Position.Y;
                            cnt += 1;
                        if (attObjDef != null)
                            Point3d ip = attObjDef.Position;
                            if ((attObjDef.Position.X >= dx) && (attObjDef.Position.Y <= dy))
                                dx = attObjDef.Position.X;
                                dy = attObjDef.Position.Y;
                // get a location of the last AttributeDefinition in the
                // block definition
                Point3d Oldloc = matchAtt.Position;
                double attTxtHeight = matchAtt.Height;
                ed.WriteMessage("\n{0:f3}", attTxtHeight);
                // calculate location of the new AttributeDefinition in the
                // block definition
                Point3d ptNewloc = new Point3d(dx, dy - attTxtHeight * 1.97, btr.Origin.Z) + btr.Origin.GetAsVector();
                //// create a AttributeDefinition
                // specify the text,tag and prompt
                string strValue = "[ Enter a new value here ]";
                string strTag = "[ Enter a new tag here ]";
                string strPrompt = "[ Enter a new prompt here ]";
                // used text style of the last attribute definition
                AttributeDefinition attDef = new AttributeDefinition(ptNewloc, strValue, strTag, strPrompt, matchAtt.TextStyleId);
                attDef.Height = matchAtt.Height;
                attDef.Layer = "0";
                attDef.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0);
                attDef.LinetypeId = matchAtt.LinetypeId;
                attDef.TextStyleId = matchAtt.TextStyleId;
                attDef.Annotative = matchAtt.Annotative;
                attDef.Preset = matchAtt.Preset;
                attDef.Invisible = matchAtt.Invisible;
                attDef.Constant = matchAtt.Constant;
                attDef.Justify = matchAtt.Justify;
                attDef.AlignmentPoint = ptNewloc;
                attDef.LockPositionInBlock = matchAtt.LockPositionInBlock;
                attDef.AdjustAlignment(db);
                // append the AttributeDefinition to the definition
                btr.UpgradeOpen();
                btr.AppendEntity(attDef);
                tr.AddNewlyCreatedDBObject(attDef, true);
                btr.DowngradeOpen();
                tr.Commit();
                ed.WriteMessage("nPerform \"_ATTSYNC _N " + blkName + "\" + command manually");
 Change block name within the code
~'J'~
Active Contributor
heinz.dober
Message 14 of 36 (302 Views)
09-13-2012 09:52 AM in reply to: Hallex
Thanks for the effort.
But unfortunately, I still have an error message
Danke für die Mühe.
Aber leider habe ich immer noch einen Fehlermeldung
DH
Hallex
Message 15 of 36 (296 Views)
09-13-2012 10:21 AM in reply to: heinz.dober
Try to remove static from void
~'J'~
Hallex
Message 16 of 36 (290 Views)
09-13-2012 10:53 AM in reply to: heinz.dober
Try this lisp you asked for
(defun add_att_to_block	(data_list /   acsp adoc att attpt atts blk blkent blk_obj blocks bname hgt inspt lastatt orig pt pts rot)
  (vl-load-com)
  (setq	adoc (vla-get-activedocument
	       (vlax-get-acad-object)
  (if (= 1 (vlax-get-property adoc 'Activespace))
    (setq acsp (vla-get-modelspace adoc))
    (setq acsp (vla-get-paperspace adoc))
  (setq blocks (vla-get-blocks adoc))
  (vla-startundomark adoc)
  (setq	blk	(vlax-ename->vla-object (setq blkent(car (entsel "\nSelect attributed block: "))))
	inspt (vlax-get blk 'insertionpoint)
	bname	(vla-get-effectivename blk)
	blk_obj	(vla-item blocks bname)
	orig (vlax-get blk_obj 'origin)
	atts (vlax-invoke blk 'Getattributes)
  (setq pts nil)
  (foreach att atts
    (setq pts (cons (vlax-get att 'insertionpoint) pts)))
  (setq pts (vl-sort pts '(lambda( a b) (and (>= (car a)(car b))(<= (cadr a)(cadr b))))))
  (setq pt (car pts))
  (setq lastatt (last (vlax-invoke blk 'Getattributes)))
  (setq hgt (vla-get-height lastatt))
  (setq rot (vla-get-rotation lastatt))
  (setq attpt (mapcar '-  (list (car  pt)(- (cadr pt)(* hgt 1.97)) (caddr pt)) inspt ))
  (setq	att (vla-AddAttribute
	      blk_obj
	      hgt
	      acAttributeModePreset
	      (car data_list)
	    (vlax-3d-point attpt)
	      (cadr data_list)
	      (caddr data_list)
  (vla-put-alignment att (vla-get-alignment lastatt))
  (vla-put-textalignmentpoint
    att
  (vla-put-rotation att rot)
  (vla-update (vlax-get-acad-object))
  (vlax-release-object blk)
  (vlax-release-object blk_obj)
  (setvar "cmdecho" 0)
  (command "_attsync" "_N" bname)
  (setvar "cmdecho" 1)
  (vla-regen adoc acactiveviewport)
  (vla-endundomark adoc)
  (princ)
;;usage:
(defun C:ia()
  ;; add Prompt, Tag and default value in list:
(add_att_to_block (list "Prompt" "TAG" "Value"))
  (princ)
~'J'~
Active Contributor
heinz.dober
Message 17 of 36 (288 Views)
09-13-2012 11:11 AM in reply to: Hallex
Thank you'll morning testing have not got Autocad
Danke werde das Morgen Testen habe hier kein Autocad
DH
Hallex
Message 18 of 36 (281 Views)
09-13-2012 12:13 PM in reply to: heinz.dober
Try code from attached text file
don't forget to rename block name and
your project name within the class
~'J'~
Active Contributor
heinz.dober
Message 19 of 36 (266 Views)
09-13-2012 09:45 PM in reply to: Hallex
Thank you
The Lisp works but not quite what I mean
The old attribute should not be moved
Danke
Das Lisp funktioniert aber nicht ganz so wie ich meine
Das alte Attribut sollte nicht verschoben werden
DH
Active Contributor
heinz.dober
Message 20 of 36 (263 Views)
09-13-2012 10:03 PM in reply to: Hallex
I said again. Net now runs
Super Thank you
But the old Att moves
and I should be able to select the block
Thank you very much
they are the best
So ich nochmal das .net läuft jetzt auch
Super Danke
aber das alte Att wird verschoben
und ich sollte den Block auswählen können
Vielen Dank
sie sind der Beste
DH
You are not logged in.
Ask the Community
