• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    BrentBurgess1980
    Attribute Definitions in BlockJig
    192 Views, 2 Replies
    10-24-2012 06:18 AM
    Hey all,
    I have a tool that inserts blocks using a jig, and it inserts the block, and attributes (if in the block), but the attributes do not go into the correct position.
    The code below is the jig that I am using.
    public class CBlockJig : EntityJig
            private Point3d pos;
            private Dictionary<string, Point3d> attPos;
            private Transaction tr;
            public CBlockJig(Transaction transaction, BlockReference br)
                : base(br)
                pos = br.Position;
                tr = transaction;
                // Initialize our dictionary with the tag /
                // AttributeDefinition position
                attPos = new Dictionary<string, Point3d>();
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
                if (btr.HasAttributeDefinitions)
                    foreach (ObjectId id in btr)
                        DBObject obj = tr.GetObject(id, OpenMode.ForRead);
                        AttributeDefinition ad = obj as AttributeDefinition;
                        if (ad != null)
                            attPos.Add(ad.Tag, ad.Position);
            protected override bool Update()
                BlockReference br = Entity as BlockReference;
                br.Position = pos;
                if (br.AttributeCollection.Count != 0)
                    foreach (ObjectId id in br.AttributeCollection)
                        AttributeReference ar = obj as AttributeReference;
                        // Apply block transform to att def position
                        if (ar != null)
                            ar.UpgradeOpen();
                            ar.Position = attPos[ar.Tag].TransformBy(br.BlockTransform);
                            Point3d bpos = br.Position;
                return true;
            protected override SamplerStatus Sampler(JigPrompts prompts)
                JigPromptPointOptions opts = new JigPromptPointOptions("\nSelect insertion point: ");
                opts.BasePoint = new Point3d(0, 0, 0);
                opts.UserInputControls = UserInputControls.NoZeroResponseAccepted;
                PromptPointResult ppr = prompts.AcquirePoint(opts);
                if (pos == ppr.Value)
                    return SamplerStatus.NoChange;
                pos = ppr.Value;
                return SamplerStatus.OK;
            public PromptStatus Run()
                Document doc =
                  Application.DocumentManager.MdiActiveDocument;
                Editor ed = doc.Editor;
                PromptResult promptResult = ed.Drag(this);
                return promptResult.Status;
     The Attributes appear in the right place while dragging, but once accepted and placed, the attribute is located as if the block were inserted at 0,0.
    Does anyone have any clue on how to fix this?
    Please use plain text.
    Re: Attribute Definitions in BlockJig
    10-24-2012 11:56 AM in reply to: BrentBurgess1980
    BrentBurgess1980
    10-29-2012 06:57 PM in reply to: gasty1001
    Thanks Gasty1001.
    The code I was using was from Kean's site, which did the funny thing with the attribute.
    I modified the spiderinnet1 one and it works well
