.NET
Attibutes VB.net 2003 ACAD 2006
3 REPLIES 3
306 Views, 3 Replies
I am getting an error on a line lower in the code as follows:
An unhandled exception of type ’System.ArgumentException’ occurred in WaterTank.exe
Additional information: Invalid argument FilterType in Select
Here is my code:
Dim A2K As Autodesk.AutoCAD.Interop.AcadApplication
Try
A2K = GetObject(, "AutoCAD.Application")
Catch
A2K = CreateObject("AutoCAD.Application")
End Try
Dim A2Kdwg As Autodesk.AutoCAD.Interop.AcadDocument = A2K.ActiveDocument
A2K.Visible = True
Dim ss As Autodesk.AutoCAD.Interop.AcadSelectionSet
Dim fType(1) As Single, fData(1) As Object
Dim i, j As Integer
Dim hndl, atts, NumBlocks As Object
Try
ss = A2Kdwg.SelectionSets.Add("ss")
Catch
'ss.Clear()
A2Kdwg.SelectionSets.Item("ss").Delete()
End Try
ss.Clear()
fType(0) = CSng(0)
fType(1) = CSng(2)
fData(0) = "INSERT"
fData(1) = "REVISION BLOCK"
<<<<<<<<<<<<< GETTING ERROR ON THE FOLLOWING LINE >>>>>>>>
ss.Select(Autodesk.AutoCAD.Interop.Common.AcSelect.acSelectionSetAll, , , fType, fData)
For i = 0 To ss.Count - 1 'This is how many times the Block exists in the drawing.
hndl = ss.Item(i).Handle
atts = ss.Item(i).GetAttributes
For j = LBound(atts) To UBound(atts) 'This is how many TAGS in a block
Debug.Write("Tag: " & atts(j).TagString & " Value: " & atts(j).TextString)
Next
Next
End Sub
3 REPLIES 3
A 'Single' is a single-precision floating point number.
Try Short or Int16 instead.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5045675@discussion.autodesk.com...
Here is my code:
Try
Catch
End Try
A2K.Visible = True
Dim i, j As Integer
Try
Catch
'ss.Clear()
End Try
ss.Clear()
fType(0) = CSng(0)
fType(1) = CSng(2)
fData(0) = "INSERT"
Next
Next
End Sub
Tony that did not fix it.
Which Reference(s) should I bee using? I am using:
Also this is the Student version.
It opens the drawing OK and seems to get the selection set
But fails on the last line
Here is new code
Try
Catch
End Try
A2K.Visible = True
A2Kdwg.Application.Documents.Open(Label2.Text)
' Dim fType(1) As Int16, fData(1) As Object
Dim fType As Int16 = 0
Dim fData As Object = "B-AttributeBlock"
Dim i, j As Integer
Try
Catch
'ss.Clear()
End Try
ss.Clear()
ss.Select(Autodesk.AutoCAD.Interop.Common.AcSelect.acSelectionSetAll, , fType, fData)
full error message
An unhandled exception of type 'System.ArgumentException' occurred in WaterTank2.exe
Additional information: Invalid argument FilterType or FilterData in Select
>>>>>>>> OK I got it to work <<<<<<<<<<<<<
this code gets a drawing already loaded.
Loops through each attribute in a Title block called B-AttributeBlock. adds them to a list box and then shows 4 of them in text boxes. also gets the drawing and path
You need these two References in VB.NET
AutoCAD = Autodesk.AutoCAD.Interop
AXDBLib = Autodesk.AutoCAD.Interop.Common
Private Sub btnLoadAttributes_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnLoadAttributes.Click
Dim AcadObj As Object
Dim Path1, dwg As String
Dim OldtitleBlock As Object
Dim ThisDrawing As Object
Dim a, b, I, j, FindSlash As Integer
'OLE Automation Object Calls
AcadObj = GetObject(, "AutoCAD.Application")
ThisDrawing = AcadObj.ActiveDocument
OldtitleBlock = False
Dim docName As String
docName = ThisDrawing.FullName
b = 1
For a = 1 To Len(docName)
FindSlash = InStr(b, docName, "\")
If FindSlash = 0 Then Exit For
b = FindSlash + 1
Next
Path1 = Microsoft.VisualBasic.Left(docName, b - 1)
dwg = Microsoft.VisualBasic.Right(docName, Len(docName) - b + 1)
Dim fType(1) As Short, fData(1) As Object
Try
ss = ThisDrawing.SelectionSets("ss")
Catch ex As Exception
ss = ThisDrawing.SelectionSets.Add("ss")
End Try
ss.Clear()
fType(0) = 0
fData(0) = "INSERT"
fType(1) = 2
fData(1) = "B-AttributeBlock"
' Now if the selection set count is greater than 0, you have every unnested instance of the block
' insert contained in the drawing. Since every item in the set is a BlockReference, you can use any
' property or method supported by AcadBlockReference and/or AcadEntity:
Dim hndl, atts As Object
For I = 0 To ss.Count - 1
OldtitleBlock = True
hndl = ss.Item(I).Handle
atts = ss.Item(I).GetAttributes
If VarType(atts) <> vbEmpty Then
Me.lstAttributes.Items.Add(" Tag: " + atts(j).TagString + " Value: " + atts(j).TextString)
If atts(j).TagString = "QTYFORJOB" Then
If Val(atts(j).TextString) 0 Then
Me.txtQty.Text = atts(j).TextString
Else
MsgBox("The Job Qty is Zero, please key in a Quantity", vbInformation, "Missing Job Qty")
'GoTo Exit_Command16_Click
If atts(j).TagString = "TITLEBLCKSIZE" Then
If Microsoft.VisualBasic.Left(atts(j).TextString, 1) = "A" Then
'A size title block
Me.txtTitleBlock.Text = "A"
Else
' B size
Me.txtTitleBlock.Text = "B"
If atts(j).TagString = "THKXWIDXLNG" Then
Me.txtMaterialCutSize.Text = atts(j).TextString
If atts(j).TagString = "MATERIALID" Then
Me.txtMaterialID.Text = atts(j).TextString
Next
Next
End Sub
”Boost
