.NET
Attaching an XRecord
3 REPLIES 3
555 Views, 3 Replies
could someone show me a very simple code-example, how to attach an extension dictionary to an AutoCAD Object und add a XRecord?
I will be grateful to you, if you would write your own examle and not copy one from the internet.
Best regards,
3 REPLIES 3
_gile
Here're some extension methods from my library (but you shouldn't copy them as there're now on the internet).
Those methods have to be called from within an active transaction.
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System;
using System.Collections.Generic;
using System.Linq;
namespace Gile.Extensions
    public static class Extensions
        public static T GetObject<T>(this ObjectId id) where T : DBObject
	    return (T)id.GetObject(OpenMode.ForRead);
        public static T GetObject<T>(this ObjectId id, OpenMode mode) where T : DBObject
            return (T)id.GetObject(mode);
        } public static void SetXrecordData(this DBDictionary dict, string key, params TypedValue[] values) { dict.SetXrecordData(key, new ResultBuffer(values)); } public static void SetXrecordData(this DBDictionary dict, string key, ResultBuffer data) { Xrecord xrec; if (dict.Contains(key)) { xrec = ((ObjectId)dict[key]).GetObject<Xrecord>(OpenMode.ForWrite); } else { dict.UpgradeOpen(); xrec = new Xrecord(); dict.SetAt(key, xrec); dict.Database.TransactionManager.TopTransaction.AddNewlyCreatedDBObject(xrec, true); } xrec.Data = data; } public static DBDictionary GetOrCreateExtensionDictionary(this DBObject obj) { if (obj.ExtensionDictionary == ObjectId.Null) { obj.UpgradeOpen(); obj.CreateExtensionDictionary(); } return obj.ExtensionDictionary.GetObject<DBDictionary>(); } public static void SetXDictionaryXrecordData(this DBObject obj, string key, params TypedValue[] values) { obj.SetXDictionaryXrecordData(key, new ResultBuffer(values)); } public static void SetXDictionaryXrecordData(this DBObject obj, string key, ResultBuffer data) { obj.GetOrCreateExtensionDictionary().SetXrecordData(key, data); } } }
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
thanks
StephenPreston
 If you were happy to use code already posted in public, then I'd also point you to the .NET Training Labs on www.autodesk.com/developautocad. (Note that this page is teporarily offline today - come back tomorrow if you get a  page not found error.
Cheers,
Stephen Preston
Autodesk Developer Network
”Boost
