.NET
AttachExternalReference problem
12 REPLIES 12
Message 1 of 13
netcai
331 Views, 12 Replies
I want use objectDBX to AttachExternalReference ,but always encount fator error,could someone tell me how to solve it?
string[] fileNames = new string[] { "Ref_S_Plan", "Ref_S_Beam", "Ref_S_Foot" };
AxDbDocumentClass axdoc = new AxDbDocumentClass();
string newName;
newName = subFolder + "\\" + fileNames[0] + ".dwg";
axdoc.SaveAs(newName, null);
AxDbDocumentClass axdoc1 = new AxDbDocumentClass();
newName = subFolder + "\\" + fileNames[1] + ".dwg";
axdoc1.SaveAs(newName, null);
AxDbDocumentClass axdoc2 = new AxDbDocumentClass();
newName = subFolder + "\\" + fileNames[2] + ".dwg";
axdoc2.SaveAs(newName, null);
double[] insertPnt = new double[] { 0, 0, 0 };
double scale = 1;
double rotation = 0;
bool bOverlay = false;
try
System.Runtime.InteropServices.Marshal.ReleaseComObject(axdoc);
catch { }
string refFileNameNoext;
refFileNameNoext = fileNames[0];
axdoc1.ModelSpace.AttachExternalReference(subFolder, refFileNameNoext, insertPnt,
scale, scale, scale, rotation, bOverlay, null);
axdoc2.ModelSpace.AttachExternalReference(subFolder, refFileNameNoext, insertPnt,
try
System.Runtime.InteropServices.Marshal.ReleaseComObject(axdoc1);
System.Runtime.InteropServices.Marshal.ReleaseComObject(axdoc2);
catch { }
12 REPLIES 12
Message 2 of 13
in reply to: netcai
What is the error that you are encountering? On what line?
Albert
wrote in message news:4872847@discussion.autodesk.com...
"Ref_S_Foot" };
string newName;
double scale = 1;
try
catch { }
try
catch { }
Message 3 of 13
netcai
in reply to: netcai
string newName;
double scale = 1;
try
catch { }
scale, scale, scale, rotation, bOverlay, null); // this line will cause a fatal error
try
catch { }
Message 4 of 13
in reply to: netcai
There are too many variables here to actually reproduce the error. What is
the error that you are getting? Does AutoCAD simply vaporizes or does it
display some error?
Albert
wrote in message news:4873818@discussion.autodesk.com...
"Ref_S_Foot" };
string newName;
double scale = 1;
try
catch { }
insertPnt,
fatal error
insertPnt,
try
catch { }
Message 5 of 13
netcai
in reply to: netcai
I have found the problem.I misunderstanding the first parameter, but a new problem appear, the ExternalReference doesn't attached to axdoc1 and axdoc2,but attached to the current drawing in autocad.
Message 6 of 13
netcai
in reply to: netcai
the following is my current code,the problem is line is added to axdoc1 and axdoc2, but External Reference isn't attached to axdoc1 and axdoc2,but attached to current drawing in autocad, it's so strange.
private static void CreateRefDrawing(String subFolder)
string newName = subFolder + "\\" + fileNames[0] + ".dwg";
string newName1 = subFolder + "\\" + fileNames[1] + ".dwg";
//axdoc1.SaveAs(newName1, null);
string newName2 = subFolder + "\\" + fileNames[2] + ".dwg";
////axdoc2.SaveAs(newName2, null);
double scale = 1;
axdoc1.ModelSpace.AddLine(new double[] { 0, 0, 0 }, new double[] { 1000, 1000, 0 });
axdoc1.ModelSpace.AttachExternalReference(newName, fileNames[0], insertPnt, scale, scale, scale, rotation, bOverlay, null);
axdoc2.ModelSpace.AddLine(new double[] { 0, 0, 0 }, new double[] { 1000, 1000, 0 });
axdoc2.ModelSpace.AttachExternalReference(newName, fileNames[0], insertPnt, scale, scale, scale, rotation, bOverlay, null);
Message 7 of 13
in reply to: netcai
Can say if this will work, but it may be
worth a try:
1. Get the managed Database from the AcadDatabase, using
Database.FromAcadDatabase(AxDbDocument.Database)
2. Save the value of HostApplicationServices.WorkingDatabase
3. Set HostApplicationServices.WorkingDatabase to the
Database obtained from the AcadDatabase.
4. Attach the xref
5. Set the value of HostApplicationServices.WorkingDatabase
back to the original value saved previously.
wrote in message news:4873960@discussion.autodesk.com...
double scale = 1;
bOverlay, null);
bOverlay, null);
Message 8 of 13
netcai
in reply to: netcai
thanks tony,I do as you suggested,but it still doesn't work for me , a fatal error will appeare when attacth external reference.
private static void CreateRefDrawing(string subFolder)
axdoc.ModelSpace.AddLine(new double[] { 0, 0, 0 }, new double[] { 1000, 1000, 0 });
double scale = 1;
Database curdb = HostApplicationServices.WorkingDatabase;
Database db = Database.FromAcadDatabase(axdoc1.Database);
HostApplicationServices.WorkingDatabase = db;
// the following line will cause a fatal error,
db = Database.FromAcadDatabase(axdoc2.Database);
axdoc2.SaveAs(newName1, null);
HostApplicationServices.WorkingDatabase = curdb;
Message 9 of 13
in reply to: netcai
I don't know if this is your problem but in your code,
you do this:
When you call ReleaseComObject(axdoc1), the Database that it
wraps is destroyed while it is the current 'WorkingDatabase',
which is almost certainly going to blow up.
Try restoring the WorkingDatabase back to curdb before
you let go of axdoc1.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4875028@discussion.autodesk.com...
double scale = 1;
null);
null);
Message 10 of 13
netcai
in reply to: netcai
tony
I tried as you told, but still occurred a error.
error: Exception occurred: 0xC0000005 (Access Violation)
system.Runtime.InteropServices.Marshal.ReleaseComObject(axdoc);
try
double scale = 1;
axdoc1.ModelSpace.AttachExternalReference(newName, fileNames[0], insertPnt, scale, scale, scale, rotation, bOverlay, null);//a fatal error occurred
catch { }
Message 11 of 13
netcai
in reply to: netcai
I tried another mothod ,and it work fine,so I think it's a bug in objectdbx.
by the way ,could someone know how to attach external reference with arx, and how to close a docment with arx.
the following is my modified codes ,it works fine.
//System.Runtime.InteropServices.Marshal.ReleaseComObject(axdoc);
double scale = 1;
try
//// the following comment line will cause a fatal error
//Database curdb = HostApplicationServices.WorkingDatabase;
//Database db = Database.FromAcadDatabase(axdoc1.Database);
//HostApplicationServices.WorkingDatabase = db;
//axdoc1.ModelSpace.AttachExternalReference(newName, fileNames[0], insertPnt, scale, scale, scale, rotation, bOverlay, null);
//HostApplicationServices.WorkingDatabase = curdb;
string refName = ".\\" + fileNames[0] + ".dwg";
AcadDocument doc1 = ActiveX.AcadApp.Documents.Open(newName1, false, null);
doc1.ModelSpace.AttachExternalReference(refName, fileNames[0], insertPnt, scale, scale, scale, rotation, bOverlay, null);
doc1.Close(true, newName1);
AcadDocument doc2 = ActiveX.AcadApp.Documents.Open(newName2, false, null);
doc2.ModelSpace.AttachExternalReference(refName, fileNames[0], insertPnt, scale, scale, scale, rotation, bOverlay, null);
doc2.Close(true, newName2);
catch { }
Message 12 of 13
netcai
in reply to: netcai
Is my judgement correct? has External reference a bug in objectdbx?
Message 13 of 13
in reply to: netcai
This was logged in our bug tracking database. Nobody looked into it yet so I
can't confirm or deny. It looks suspeciously like a bug.
Albert
wrote in message news:4881355@discussion.autodesk.com...
”Boost
