ArxWizards install problem
I'm trying to install the ArxWizards, but keep on reciving this error attached. I'm working with autocad 2012 and visual studio 2010.
any suggestion?
Balaji_Ram
Can you please try setting the User Access Control Settings (UAC) to "Never Notify" and then start the ArxWizards installer ?
A system restart may be required after the UAC setting is modified.
Hope this helps.
Cheers,
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji
hi Balaji,
thanks for respond. Installation did work after I did what you said, so thanks. Now, I enter the Visual Studio starting a new project, but in the New Project dialog/Visual C# Projects there is no “AutoCAD Managed C# Project” template. 😞
Balaji_Ram
The AutoCAD .Net Wizard is different from the ObjectARX Wizard.
You can get it from the Developer Center. Here is the link :
AutoCAD .Net Wizard
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
Cheers,
Balaji
Balaji
Balaji, you are tha man! It works! thanks...
thank,it is almost not been mention in chinese web site,you help me a lot.
