.NET
GeoSchaap
Message 1 of 6 (611 Views)
ArxWizards install problem
611 Views, 5 Replies
06-05-2011 08:16 AM
I'm trying to install the ArxWizards, but keep on reciving this error attached. I'm working with autocad 2012 and visual studio 2010.
any suggestion?
ADN Support Specialist
Balaji_Ram
Message 2 of 6 (590 Views)
Re: ArxWizards install problem
06-05-2011 08:17 PM in reply to: GeoSchaap
Can you please try setting the User Access Control Settings (UAC) to "Never Notify" and then start the ArxWizards installer ?
A system restart may be required after the UAC setting is modified.
Hope this helps.
Cheers,
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji
GeoSchaap
Message 3 of 6 (583 Views)
06-05-2011 10:58 PM in reply to: GeoSchaap
hi Balaji,
thanks for respond. Installation did work after I did what you said, so thanks. Now, I enter the Visual Studio starting a new project, but in the New Project dialog/Visual C# Projects there is no “AutoCAD Managed C# Project” template. :smileysad:
Balaji_Ram
Message 4 of 6 (578 Views)
06-05-2011 11:18 PM in reply to: GeoSchaap
The AutoCAD .Net Wizard is different from the ObjectARX Wizard.
You can get it from the Developer Center. Here is the link :
AutoCAD .Net Wizard
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
Cheers,
Balaji
Balaji
GeoSchaap
Message 5 of 6 (575 Views)
06-06-2011 12:09 AM in reply to: Balaji_Ram
Balaji, you are tha man! It works! thanks...
New Member
karlmt
Message 6 of 6 (277 Views)
04-01-2013 06:17 PM in reply to: Balaji_Ram
thank,it is almost not been mention in chinese web site,you help me a lot.
You are not logged in.
Ask the Community
