.NET
Array polar with donut
6 REPLIES 6
franciscocsilva
756 Views, 6 Replies
      Dim Varao As Autodesk.AutoCAD.DatabaseServices.Polyline = New Autodesk.AutoCAD.DatabaseServices.Polyline()
      If ComboBox1.SelectedIndex = 0 Then
        Varao.SetDatabaseDefaults()
        Varao.AddVertexAt(0, New Point2d(0+0.025, 0), 1, (0.02), (0.02))
        Varao.AddVertexAt(1, New Point2d(0-0.025, 0), 1, (0.02), (0.02))
        Varao.Closed = True
        ms.AppendEntity(Varao)
        trans.AddNewlyCreatedDBObject(Varao, True)
      Dim Count As Integer = 1
      Dim dAng As Double = (2 * PI) / TextBox1.Text
      Dim PontoRotacao As Point2d = New Point2d(pontoinsert.X, pontoinsert.Y)
      While (Count < TextBox1.Text)
        Dim VaraoClone As Entity = Varao.Clone()
        Dim acExts As Extents3d
        Dim acPtObjBase As Point2d
'I have here is the problem (circle)
        Dim ArrayFerro As Circle = VaraoClone
        If IsDBNull(ArrayFerro) = False Then
          acPtObjBase = New Point2d(ArrayFerro.Center.X, ArrayFerro.Center.Y)
        Else
          acExts = VaraoClone.Bounds.GetValueOrDefault()
          acPtObjBase = New Point2d(acExts.MinPoint.X, acExts.MaxPoint.Y)
        Dim dDist As Double = PontoRotacao.GetDistanceTo(acPtObjBase)
        Dim dAngFromX As Double = PontoRotacao.GetVectorTo(acPtObjBase).Angle
        Dim acPt2dTo As Point2d = PolarPoints(PontoRotacao, (Count * dAng) + dAngFromX, dDist)
        Dim acVec2d As Vector2d = acPtObjBase.GetVectorTo(acPt2dTo)
        Dim acVec3d As Vector3d = New Vector3d(acVec2d.X, acVec2d.Y, 0)
        VaraoClone.TransformBy(Matrix3d.Displacement(acVec3d))
        ms.AppendEntity(VaraoClone)
        trans.AddNewlyCreatedDBObject(VaraoClone, True)
        Count = Count + 1
      End While
my problem  Dim ArrayFerro As Circle = VaraoClone
System.InvalidCastException: Unable to cast object of type 'Autodesk.AutoCAD.DatabaseServices.Polyline' to type 'Autodesk.AutoCAD.DatabaseServices.Circle'.
Francisco Silva
www.lojadosdesenhadores.blogspot.com
6 REPLIES 6
the errormessage tells what's wrong!
You declared a variable to be able hold an object of type DatabaseServices.Circle
.... and then you try to store an object of type DatabaseServices.Polyline in it.
ArrayFerro = VaraoClone
Well you wrote all in one statement, I splitted it to declare what part of statement is what part of my description.
And a polyline with two vertices, one arc and option closed may look like a circle, but does not make an object of type circle 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
aand what is the solution? if you please
Francisco Silva
There is no solution except of "you cannot cast an object of type DatabaseServices.Polyine to type DatabaseServices.Circle"
I see your code as a sample you built to show something as code-snippet (and not to bypass your full application, I think) but I don't understand what this code should do, sorry.
I first don't understand why you draw a Polyline to get a shape like a circle (and then need a circle), why not starting with a circle?
If your situation is that you have already a Polyline existing in the drawing-database, then you have to check the polyline itself, not every polyline has arcs, so even splitting the polyline into it's parts (and then having lines and/or arcs) you will not get a Center.X or Center.Y for line-segments.
I want to help, but sorry that I don't understand what your goal is. Could you please descibe it? What do you have (input parameters or existing objects) and what do you want to get. If it is hard to describe ==> upload drawings.
- alfred -
Alfred NESWADBA
hi,
What I need is a thread to draw a donut and then draw a Polar Array of it around a centre point that I can designate.
Francisco Silva
take a look to this, hope that's what you were looking for (and if not that you can adapt parts of it to your needs)
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Public Class cAutodeskForum2011
   Public Shared Function createArrayOfDonuts() As Boolean
      Dim tRetVal As Boolean = False
      Dim tAcadDoc As Document = Nothing
      Dim tAcadDocLock As DocumentLock = Nothing
      Dim tTrAct As Transaction = Nothing
      Try
         tAcadDoc = Application.DocumentManager.MdiActiveDocument
         tAcadDocLock = tAcadDoc.LockDocument
         tTrAct = tAcadDoc.TransactionManager.StartTransaction
         Dim tGoOn As Boolean = True
         'get Center of polar array
         Dim tPos As Point3d
         If tGoOn Then
            Dim tPntGet As PromptPointResult = tAcadDoc.Editor.GetPoint(vbNewLine & "Center of polar array: ")
            If tPntGet.Status = PromptStatus.OK Then
               tPos = tPntGet.Value
            Else
               tGoOn = False
               tAcadDoc.Editor.WriteMessage("Center of Array: input canceled")
         'get Radius of polar array
         Dim tRad As Double = 0.0
         If tGoOn Then
            Dim tDistOpts As PromptDistanceOptions = New PromptDistanceOptions(vbNewLine & "Radius of polar array: ")
            tDistOpts.AllowNegative = False
            tDistOpts.AllowNone = False
            tDistOpts.AllowZero = False
            tDistOpts.BasePoint = tPos
            tDistOpts.UseBasePoint = True
            Dim tDblGet As PromptDoubleResult = tAcadDoc.Editor.GetDistance(tDistOpts)
            If tDblGet.Status = PromptStatus.OK Then
               tRad = tDblGet.Value
            Else
               tGoOn = False
               tAcadDoc.Editor.WriteMessage("Radius of polar array: input canceled")
         'you can now also get these values by requesting the user or by passing as parameters to this function
         Dim tStartAngle As Double = 0
         Dim tEndAngle As Double = Math.PI * 2
         Dim tNumberOfItems As Double = 20
         Dim tDonutRadius As Double = tRad / 10.0
         Dim tDonutPLineWidth As Double = tRad / 100.0
         If tGoOn Then
            Dim tDonutBasePoly As Polyline = getDonut(tDonutRadius, tDonutPLineWidth)
            If tDonutBasePoly IsNot Nothing Then
               'move the basepoly from 0,0,0 (where it is created) to the center of the array
               Dim tBaseMat As Matrix3d = Matrix3d.Displacement(tPos.GetAsVector)
               tDonutBasePoly.TransformBy(tBaseMat)
               'ok, seems to have all to draw the objects
               'get modelspace or paperspace, whatever is current
               Dim tSpace As BlockTableRecord = CType(tTrAct.GetObject(tAcadDoc.Database.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
               For i As Double = tStartAngle To tEndAngle Step ((tEndAngle - tStartAngle) / tNumberOfItems)
                  Dim tNewPoly As Polyline = CType(tDonutBasePoly.Clone, Polyline)
                  Dim tMat As Matrix3d = Matrix3d.Displacement(New Vector3d(tRad * Math.Sin(i), tRad * Math.Cos(i), 0))
                  tNewPoly.TransformBy(tMat)
                  tSpace.AppendEntity(tNewPoly)
                  tTrAct.AddNewlyCreatedDBObject(tNewPoly, True)
               Next
               tTrAct.Commit()
tRetVal = true
 'clean up memory tDonutBasePoly.Dispose() tDonutBasePoly = Nothing Else 'should not land here! End If End If Catch ex As Exception Call MsgBox("Error occured!" & vbNewLine & ex.Message) Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing If tAcadDocLock IsNot Nothing Then tAcadDocLock.Dispose() : tAcadDocLock = Nothing End Try Return tRetVal End Function Private Shared Function getDonut(ByVal Rad As Double, ByVal PlineWidth As Double) As Polyline Dim tPoly As Polyline = Nothing Try tPoly = New Polyline tPoly.SetDatabaseDefaults() tPoly.AddVertexAt(0, New Point2d(Rad, 0), 1, PlineWidth, PlineWidth) tPoly.AddVertexAt(0, New Point2d(-Rad, 0), 1, PlineWidth, PlineWidth) tPoly.Closed = True Catch ex As Exception If tPoly IsNot Nothing Then tPoly.Dispose() : tPoly = Nothing Throw New Exception("Error creating Polyline in function 'drawDonut'", ex) End Try Return tPoly End Function End Class
HTH, - alfred -
Alfred NESWADBA
thanks, but i need a solution for my thread.
Francisco Silva
”Boost
