• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Aotocad Map Toolbar
    95 Views, 2 Replies
    04-19-2012 12:03 AM
    Hi...
    How can I create a toolbar (say with one button) in AutoCad Map by using C# (.Net object arx).
    If any body can provide sample code ..will b much better.
    Murali
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Aotocad Map Toolbar
    04-19-2012 06:19 AM in reply to: murali.pandey
    You can start from that post: http://forums.autodesk.com/t5/NET/Create-toolbar/m-p/1687527#M3911
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    04-24-2012 11:06 PM in reply to: Alexander.Rivilis
    Thanks!
    One more thing ..I have to execute other command by clicking the added toolbar button.How can I do by using C#.
    (I just want to the way how I can create the toolbar then how to load it and then how to excute the command on clicking the toolbar button using C#)
