I have Microsoft Visual C++ 2005 Express Edition, and I would like to try the .NET api using C++/CLI syntax the same way I use c# or vb.net (managed not directly using ObjectArx). All the samples from Autodesk are in c# or VB.NET.
[CommandMethod("COMINTEROP", CommandFlags.Session)]
public static void ComInteropCommand() {
how to register an Autocad command using C++/CLI syntax ?
Thanks in advance.
