.NET
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Another DWGThumbna il post
- Highlight
- Email to a Friend
- Report Inappropriate Content
Sorry - but I just can't get this thing to work (DWGThumbnail). I have read everything I could find.
Here is my problem in a nutshell: I am creating a Windows forms application that includes the AutoCAD DWG Thumbnail OCX control on the form. I can't get this to work on a Windows 7 64bit machine.
On my develpment machine (which is Windows Vista 32 bit), I created a small Winform app, added the COM AutoCAD Thumbnail OCX reference (DWGTHUMBNAIL.OCX) version 2.0.
Then placed this control on my form. Visual Studio then adds the references to the project: Interop.DWGTHUMBNAILLib.dll and AxInterop.DWGTHUMBNAILLib.dll. I set them to 'Copy Local'. So far so good.
I run the project in debug mode and it starts and runs fine (on the development machine).
I publish the app using ClickOnce (how I have deployed many apps).
Install the app on the Win7 64 bit machine and get: 'Exception from HRESULT: 0x80040154 REGDB_E_CLASSNOTREG...'
I have tried copying Both DLL's and registering them with Regsvr32, I have tried using Regasm, every which way!
Is this the correct version of the DWG Thumbnail control?
Why can't Autodesk make a .Net assembly of it???
Note - I am not a member of ADN, so I can't get any stuff there.
Help!!! ![]()
Re: Another DWGThumbna il post
- Highlight
- Email to a Friend
What about 3rd party options? Are there any out there? I'd be willing to pay for a reliable, stable .Net AutoCAD thumbnail control. This seems harder than it should be...
- Highlight
- Email to a Friend
Hi there please look at the attached class file.
This should help you. More info about this class can be found at the swamp.
http://www.theswamp.org/index.php#2
Kind regards,
Irvin
- Highlight
- Email to a Friend
Thanks - I have not registered at TheSwamp yet, but the class file looks good, do you possibly have it in VB?
- Highlight
- Email to a Friend
Imports System
Imports System.Drawing
Imports System.Drawing.Imaging
Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Class acThumbnailReader
<StructLayout(LayoutKind.Sequential)> _
Private Structure BITMAPINFOHEADER
Public biSize As Integer
Public biWidth As Integer
Public biHeight As Integer
Public biPlanes As Short
Public biBitCount As Short
Public biCompression As Integer
Public biSizeImage As Integer
Public biXPelsPerMeter As Integer
Public biYPelsPerMeter As Integer
Public biClrUsed As Integer
Public biClrImportant As Integer
End Structure
Private Structure IMGREC
Public bytType As Byte
Public lngStart As Integer
Public lngLen As Integer
End Structure
Private Structure RGBQUAD
Public rgbBlue As Byte
Public rgbGreen As Byte
Public rgbRed As Byte
Public rgbReserved As Byte
End Structure
Public Shared Function GetThumbnail(strFile As String) As Bitmap
Return GetThumbnail(strFile, True, False, "")
End Function
Public Shared Function GetThumbnail(strFile As String, boolRetainBackColor As Boolean) As Bitmap
Return GetThumbnail(strFile, boolRetainBackColor, False, "")
End Function
Public Shared Function GetThumbnail(strFile As String, boolRetainBackColor As Boolean, boolSaveToFile As Boolean) As Bitmap
Return GetThumbnail(strFile, boolRetainBackColor, boolSaveToFile, "")
End Function
Public Shared Function GetThumbnail(strFile As String, boolRetainBackColor As Boolean, boolSaveToFile As Boolean, strSaveName As String) As Bitmap
Dim bmp As New Bitmap(1, 1, PixelFormat.Format8bppIndexed)
Dim bytCnt As Byte
Dim bytBMPBuff As Byte()
Dim lngImgLoc As Integer
Dim fs As FileStream = Nothing
Dim br As BinaryReader = Nothing
Dim lngCurLoc As Integer
Dim lngY As Integer
Dim lngX As Integer
Dim lngColor As Integer
Dim lngCnt As Integer
Dim intCnt As Short
Dim udtRec As IMGREC
Dim udtColors As RGBQUAD()
Dim udtColor As RGBQUAD
Dim udtHeader As BITMAPINFOHEADER
Dim intRed As Short
Dim intGreen As Short
Dim intBlue As Short
Try
If File.Exists(strFile) Then
fs = File.OpenRead(strFile)
br = New BinaryReader(fs)
fs.Seek(13, SeekOrigin.Begin)
lngImgLoc = br.ReadInt32()
fs.Seek(lngImgLoc + 17, SeekOrigin.Begin)
lngCurLoc = lngImgLoc + 17
fs.Seek(lngCurLoc + 3, SeekOrigin.Begin)
bytCnt = br.ReadByte()
If bytCnt > 1 Then
For intCnt = 0 To bytCnt - 1
udtRec.bytType = br.ReadByte()
udtRec.lngStart = br.ReadInt32()
udtRec.lngLen = br.ReadInt32()
If udtRec.bytType = 2 Then
fs.Seek(udtRec.lngStart, SeekOrigin.Begin)
udtHeader.biSize = br.ReadInt32()
udtHeader.biWidth = br.ReadInt32()
udtHeader.biHeight = br.ReadInt32()
udtHeader.biPlanes = br.ReadInt16()
udtHeader.biBitCount = br.ReadInt16()
udtHeader.biCompression = br.ReadInt32()
udtHeader.biSizeImage = br.ReadInt32()
udtHeader.biXPelsPerMeter = br.ReadInt32()
udtHeader.biYPelsPerMeter = br.ReadInt32()
udtHeader.biClrUsed = br.ReadInt32()
udtHeader.biClrImportant = br.ReadInt32()
bytBMPBuff = New Byte(udtRec.lngLen) {}
If udtHeader.biBitCount = 8 Then
udtColors = New RGBQUAD(255) {}
For count As Integer = 0 To 255
udtColors(count).rgbBlue = br.ReadByte()
udtColors(count).rgbGreen = br.ReadByte()
udtColors(count).rgbRed = br.ReadByte()
udtColors(count).rgbReserved = br.ReadByte()
Next
fs.Seek(udtRec.lngStart - 1, SeekOrigin.Begin)
For count As Integer = 0 To udtRec.lngLen
bytBMPBuff(count) = br.ReadByte()
Next
bmp = New Bitmap(udtHeader.biWidth, udtHeader.biHeight)
lngCnt = 0
For lngY = 1 To udtHeader.biHeight
For lngX = udtHeader.biWidth To 1 Step -1
lngColor = bytBMPBuff(bytBMPBuff.GetUpperBound(0) - lngCnt)
udtColor = udtColors(lngColor)
intRed = Convert.ToInt16(udtColor.rgbRed)
intGreen = Convert.ToInt16(udtColor.rgbGreen)
intBlue = Convert.ToInt16(udtColor.rgbBlue)
lngColor = ColorTranslator.ToOle(Color.FromArgb(intRed, intGreen, intBlue))
If boolRetainBackColor = False Then
If lngColor = ColorTranslator.ToOle(Color.Black) Then
lngColor = ColorTranslator.ToOle(Color.White)
Else
If lngColor = ColorTranslator.ToOle(Color.White) Then
bmp.SetPixel(lngX - 1, lngY - 1, ColorTranslator.FromOle(lngColor))
lngCnt += 1
Next
Next
GoTo Exit_Here
Else
If udtRec.bytType = 3 Then
GoTo Exit_Here
Next
Catch ex As Exception
MessageBox.Show(ex.Message.ToString())
GoTo Exit_Here
End Try
Exit_Here:
If br IsNot Nothing Then
br.Close()
fs.Close()
fs.Dispose()
If boolSaveToFile = True Then
If strSaveName = "" Then
Dim fName As String
fName = [String].Concat(Path.GetTempPath(), Path.GetFileNameWithoutExtension(Path.GetRandomFil eName()), ".bmp")
bmp.Save(fName)
Else
bmp.Save(strSaveName)
Return bmp
End Function
End Class
- Highlight
- Email to a Friend
THANK YOU!!!! ![]()
That works great. I removed the DwgThumbnail references and control, created the acThumbnailReader class, used it on my form, published it, and it works on the 64bit system.
Thanks again.
Jim
- Highlight
- Email to a Friend
Glad to help you with your problem.
But thanks go out to the original programmers.
Kind regards,
Irvin
- Highlight
- Email to a Friend
Can you explain how you used the class? (broad steps, if you can tell)
Does it work on 32 bit m/c too?
Regards
Shreenivas Potnis
