Hi all
I've made a program for setting all hatches in a drawing to be annotative.
This program traverses through all blocks and subblocks which you can't do with the quick select function.
The program worked well before AutoCAD mechanical version 2012. But now some hatches behave strange when they are changed to annotative hatches. They appear as solid hatches even though they are actually ANSI31. If you then toggle them back to non-annotative they some times revert to their normal state and sometimes remain as solid. I can’t figure out if there is a common denominator to the misbehaviour. And I don’t really know if it’s actually my program that does this.
Have any one experienced this behaviour with annotative hatch?
Can any one se if my program might cause this behaviour?
I have inserted the code so you can see what I’m doing.
Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Internal Imports Autodesk.AutoCAD.ApplicationServices 'Imports Autodesk.AutoCAD.Interop Namespace ACADTools Public Module Annotate Public Sub AddScale(ByVal paperUnit As Double, ByVal drawingUnit As Double) Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Try Dim ocm As ObjectContextManager = db.ObjectContextManager If ocm IsNot Nothing Then ' Now get the Annotation Scaling context collection ' (named ACDB_ANNOTATIONSCALES_COLLECTION) Dim occ As ObjectContextCollection = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES") If (occ IsNot Nothing) Then '// Create a brand new scale context Dim asc As AnnotationScale = New AnnotationScale() asc.Name = paperUnit.ToString() & ":" & drawingUnit.ToString() asc.PaperUnits = paperUnit asc.DrawingUnits = drawingUnit '// Add it to the drawing's context collection occ.AddContext(asc) End If End If Catch ex As System.Exception SendMessage(ex.ToString()) End Try End Sub Public Sub RemoveAnnotativeHatch() ThisDrawing.StartUndoMark() Dim oHatch As AcadHatch Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim ocm As ObjectContextManager = db.ObjectContextManager Dim occ As ObjectContextCollection = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES") Dim tr As Transaction = doc.TransactionManager.StartTransaction() Dim blockstoignore() As String = InputBox("Please write Block names to ignore (comma seperated)", "Block to ignore", "HT logo*,_*,*Border*,*Head*,*Drawing*").Split(",") Dim ignoreblock As Boolean For Each oBlock As AcadBlock In ThisDrawing.Blocks For Each blockname As String In blockstoignore If oBlock.Name.ToLower.Trim Like blockname.ToLower.Trim Then ignoreblock = True Next If Not ignoreblock Then For Each oAcadObject As AcadObject In oBlock If TypeOf (oAcadObject) Is AcadHatch Then oHatch = CType(oAcadObject, AcadHatch) Dim obj As DBObject = tr.GetObject(New ObjectId(New IntPtr(oAcadObject.ObjectID)), OpenMode.ForRead) If (obj IsNot Nothing) Then obj.UpgradeOpen() obj.Annotative = AnnotativeStates.False End If End If Next End If ignoreblock = False Next tr.Commit() 'End Using ThisDrawing.EndUndoMark() End Sub Public Sub AttachScale() ThisDrawing.StartUndoMark() Dim oHatch As AcadHatch Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim ocm As ObjectContextManager = db.ObjectContextManager Dim occ As ObjectContextCollection = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES") Dim tr As Transaction = doc.TransactionManager.StartTransaction() Dim Scales() As String = InputBox("Please write Scales (comma seperated)", "Scales to add", "2:1,1:1,1:2,1:2.5,1:4,1:5,1:7,1:7.5,1:10,1:12,1:12.5,1:15,1:20,1:25,1:33.33,1:50,1:75,1:100").Split(",") Dim blockstoignore() As String = InputBox("Please write Block names to ignore (comma seperated)", "Block to ignore", "HT logo*,_*,*Border*,*Drawing*").Split(",") For Each scale As String In Scales Dim oc As ObjectContext = occ.GetContext(scale.Trim()) If oc Is Nothing Then AddScale(scale.Split(":")(0), scale.Split(":")(1)) Next Dim ignoreblock As Boolean For Each oBlock As AcadBlock In ThisDrawing.Blocks For Each blockname As String In blockstoignore If oBlock.Name.ToLower.Trim Like blockname.ToLower.Trim Then ignoreblock = True Next If Not ignoreblock Then For Each oAcadObject As AcadObject In oBlock If TypeOf (oAcadObject) Is AcadHatch Then oHatch = CType(oAcadObject, AcadHatch) If oHatch.PatternName = "ANSI31" Or oHatch.PatternName = "LINE" Then Dim obj As DBObject = tr.GetObject(New ObjectId(New IntPtr(oAcadObject.ObjectID)), OpenMode.ForRead) If (obj IsNot Nothing) Then obj.UpgradeOpen() obj.Annotative = AnnotativeStates.True For Each scale As String In Scales Try ObjectContexts.AddContext(obj, occ.GetContext(scale.Trim())) Catch SendMessage(scale & " not found") End Try Next End If End If End If Next End If ignoreblock = False Next tr.Commit() 'End Using ThisDrawing.EndUndoMark() End Sub End Module End Namespace
Hi all
I think i've found out why this happens.
It's seems to be some new behavior i AutoCAD, where if the hatch is so big it can't be seen the hatch is automatically shown as a solid.
This behavior is not desirable in our drawings though.
Does anyone know how to make it work as in pre 2012 AutoCAD?
br Magnus
it's known to Autodesk and they tell us, it's "as designed", you'll find a discussion >>>in this thread<<< plus a site for a feedback "if we don't like this" 😉
- alfred -
