.NET
Valued Contributor
Ertqwa
Message 1 of 6 (267 Views)
Annotation scale
267 Views, 5 Replies
06-14-2013 02:10 PM
If I have an annotative object, with multiple annotative scales, but not the current one, AutoCAD will display it picking one of its annotative scales.
How do I find out which annotative scale AutoCAD is using to display an annotative object that has not the current annotation scale?
Thank you.
ADN Support Specialist
augusto.goncalves
Message 2 of 6 (224 Views)
Re: Annotation scale
06-18-2013 09:33 AM in reply to: Ertqwa
Maybe this blog post will answer you: http://adndevblog.typepad.com/autocad/2012/05/annotation-scale-being-used-in-model-space.html
Augusto Goncalves
Autodesk Developer Network
Valued Contributor
Ertqwa
Message 3 of 6 (196 Views)
06-22-2013 03:06 PM in reply to: augusto.goncalves
That post doesn't answer my question, it shows how to get the current  annotation scale in modelspace.
Thank you for the reply.
Balaji_Ram
Message 4 of 6 (180 Views)
06-24-2013 04:52 AM in reply to: Ertqwa
There is no direct API to get the annotation scale that the entity is using.
As a workaround, you can try digging a little deep into the extension dictionary and getting it by looking for a DXF code 300. Using ArxDbg snoop tool, you can locate it.
I have shared a C++ code that does this which might be of some help to investigate this further.
I am having issues in uploading the zip file to this forum post. So I have shared it using dropbox :
https://www.dropbox.com/s/p8kjcm4l19r7iux/SampleCode.zip
Balaji
Developer Technical Services
Valued Contributor
Ertqwa
Message 5 of 6 (151 Views)
06-26-2013 09:53 PM in reply to: Balaji_Ram
Oh that is too bad. But good to know.
I'll look into your suggestion. The link did not work for me.
Balaji_Ram
Message 6 of 6 (146 Views)
06-26-2013 10:28 PM in reply to: Ertqwa
Sorry, I might have removed it while clearing files from my dropbox folder.
Here is the link :
https://www.dropbox.com/s/8eodlfejmdzukvq/EntityAnnoScale.zip
Balaji
You are not logged in.
Ask the Community
