• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    Alternative method for SetFocusToDwgView()?
    77 Views, 1 Replies
    01-15-2013 01:02 AM
    Unfortunately, ARX 2007 does not provide Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView().
    What would be the best way to mimic this method?
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Alternative method for SetFocusToDwgView()?
    01-15-2013 03:08 AM in reply to: dynamicscope
    Try this code (not the same as SetFocusToDwgView but can be helpful):
    [DllImport("user32.dll")]
    extern static IntPtr SetFocus(IntPtr hWnd);
    static void SetFocusToActiveDocument()
      SetFocus(Application.DocumentManager.MdiActiveDocument.Window.Handle);
    static void SetFocusToMainWindow()
      SetFocus(Application.MainWindow.Handle);
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
