.NET
Active Contributor
xdbk07
Message 1 of 3 (527 Views)
Adjust attribute text width
527 Views, 2 Replies
06-25-2013 12:32 AM
Hi All,
Is there any way to adjust width of attribute text so that it is not out of contained block. The attribute is set at left alignment and width factor <=1. Please see picture below:
Thanks so much.
norman.yuan
Message 2 of 3 (496 Views)
Re: Adjust attribute text width
06-25-2013 02:24 PM in reply to: xdbk07
You need to find out the attribte text's width, and then you need to find out the allowed/desired width. Once you get these 2 widths, you can calculate the WidthFactor of AttributeReference.
I put together some quick code that does it:
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(AttributeWidthFactor.MyCommands))]
namespace AttributeWidthFactor
    public class MyCommands
        [CommandMethod("AttWidth")]
        public static void SetAttrWidthFactor()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            //Pick an attributereference in a block
            PromptNestedEntityOptions opt = new
                PromptNestedEntityOptions("\nPick an attribute:");
            PromptNestedEntityResult res = ed.GetNestedEntity(opt);
            if (res.Status == PromptStatus.OK)
                if (res.ObjectId.ObjectClass.DxfName.ToUpper() == "ATTRIB")
                    //Ask user to pick a distance as desired width for
                    //the attribute to fit in. Based on the block, the width
                    //could be a known value
                    PromptPointOptions popt = new
                        PromptPointOptions("\nPick width base point:");
                    PromptPointResult pres = ed.GetPoint(popt);
                    if (pres.Status != PromptStatus.OK) return;
                    Point3d basePt = pres.Value;
                    PromptDistanceOptions dopt =
                        new PromptDistanceOptions("\nPick width: ");
                    dopt.UseBasePoint = true;
                    dopt.BasePoint = basePt;
                    PromptDoubleResult dres = ed.GetDistance(dopt);
                    if (dres.Status != PromptStatus.OK) return;
                    //This is the width we want to fit the attribute text's width
                    double w = dres.Value;
                    using (Transaction tran =
                        dwg.TransactionManager.StartTransaction())
                        AttributeReference att = (AttributeReference)tran.GetObject(
                            res.ObjectId, OpenMode.ForWrite);
                        //Get attribute's width, assuming it is placed horizontally
                        double aw = Math.Abs(att.GeometricExtents.MaxPoint.X
                            - att.GeometricExtents.MinPoint.X);
                        //This is the WidthFactor
                        double factor = w / aw;
                        att.WidthFactor = factor;
                        tran.Commit();
                else
                    Application.ShowAlertDialog("Not an attribute!");
 The code will stretch or narrow the attribute to fit it into a given width.
HTH
Active Contributor
xdbk07
Message 3 of 3 (462 Views)
06-26-2013 06:08 PM in reply to: xdbk07
Thanks a lot. It's OK.
You are not logged in.
Ask the Community
