.NET
Member
rbastiaans
Message 1 of 3 (196 Views)
Adding trusted locations through the api
196 Views, 2 Replies
02-12-2014 07:41 AM
Hi Guys,
Does anybody know if it's possible to add trusted locations through the api in 2014?
Thanks.
Remco
mzakiralam
Message 2 of 3 (186 Views)
Re: Adding trusted locations through the api
02-12-2014 08:57 AM in reply to: rbastiaans
I think you can add trusted path using "TRUSTEDPATHS" System variable. But for Details you can go through below two links which might be useful for you:
http://adndevblog.typepad.com/autocad/2013/01/autodesk-autoloader-white-paper.html
http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-2FB4611D-F141-48D5-9B6E-460EB59351AF...
Member
rbastiaans
Message 3 of 3 (138 Views)
02-16-2014 11:51 PM in reply to: mzakiralam
Thanks!
I didn't know you could add two paths using the command line, now I can implement it in my .net solution as well.
Just use a semicolon between the two paths.
You are not logged in.
Ask the Community
