That's because they are the only dialogs you can add tabs to.
I can't tell you much about the AECPROJECTSTANDARDS dialog, but if the
dialog is not a managed component and there's no API that is for extending
it, there's not much chance you can do it, other than by resorting to
raw/native WinAPI hooks and calls.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message
news:6270261@discussion.autodesk.com...
Thanks for the reply.
I was not able to see any other events apart from for these 3 dialog!!!
Actually I am trying to add Tab for Vports command and
AECPROJECTSTANDARDS command of AutoCAD Architecture.
I have read in API documentation, you can add tab to any tab extensible
dialog. But there is no list of dialog which can be extended or unless there
is an event to do so.
Can you please guide me further on how to add Tabs for above 2 dialogs.
