.NET
.NET
Valued Contributor
RamanSBV
Message 1 of 5 (152 Views)
Adding custom code in reference editing and RefEdit command
152 Views, 4 Replies
06-06-2012 10:41 PM
Could you please any body suggest, how i can add .net code on reference editing and refedit command.
Raman
Alfred.NESWADBA
Message 2 of 5 (143 Views)
Re: Adding custom code in reference editing and RefEdit command
06-07-2012 01:01 AM in reply to: RamanSBV
follow these steps:
  • get the BlockTable within your current drawing
  • go through the items in the BlockTable (type ObjectID for BlockTableRecord) and check if it's your XRef
  • if you found it you have access to it's database then to modify it.
- alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 3 of 5 (141 Views)
06-07-2012 04:20 AM in reply to: RamanSBV
Do you want to replace the command REFEDIT with your code?
Then try this code: http://forums.autodesk.com/t5/NET/Override-default-commands/m-p/3402455#M28099
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
RamanSBV
Message 4 of 5 (127 Views)
06-07-2012 10:42 PM in reply to: Alexander.Rivilis
Thanks for this link.....
Could you please guide me how i can get the "Select reference:" value in REFEDIT command.
Raman
Valued Contributor
RamanSBV
Message 5 of 5 (124 Views)
06-07-2012 11:18 PM in reply to: RamanSBV
Here,
How i can get the "Select reference:"  Xref file path value in REFEDIT command.
Please guide me.
Raman
