.NET
Distinguished Contributor
GeeHaa
Message 1 of 8 (360 Views)
Adding a document to documentmanager collection
360 Views, 7 Replies
07-30-2013 10:31 AM
The code below crashes with an "attempt to write to protected memory"  in debug mode (it crashes when it hits acDocMgr.add)but in the Release version it works fine. Should I be worried? I am using Command Flags.Session
Dim acDocMgr As DocumentCollection = Application.DocumentManager
Dim pStyle As Integer = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("PSTYLEMODE")
Dim acDoc As Document = Nothing
If pStyle = 1 Then
   acDoc = acDocMgr.Add("acad.dwt")
Else
acDoc = acDocMgr.Add("acad -Named Plot Styles.dwt")
End If
 Thanks in Advance
Valued Contributor
sszabo
Message 2 of 8 (351 Views)
Re: Adding a document to documentmanager collection
07-30-2013 11:11 AM in reply to: GeeHaa
try this: acDoc = DocumentCollectionExtension.Add(acDocMgr, "acad.dwt")instead.
GeeHaa
Message 3 of 8 (346 Views)
07-30-2013 11:29 AM in reply to: GeeHaa
Thanks for the reply,
I tried using the documentcollectionextension but it still has the same error.
this appears in the imediate window
A first chance exception of type 'Autodesk.AutoCAD.Runtime.Exception' occurred in AcdbMgd.dll
Valued Contributor
sszabo
Message 4 of 8 (318 Views)
07-31-2013 03:56 AM in reply to: GeeHaa
It sounds like a multi threading issue but without the whole project attached I can't tell what's going on, sorry.
Hallex
Message 5 of 8 (299 Views)
07-31-2013 11:45 AM in reply to: GeeHaa
Try add to Reference: accoremgd.dll
GeeHaa
Message 6 of 8 (289 Views)
07-31-2013 12:41 PM in reply to: Hallex
Nevermind I figured it out. I have a startup sequence in my ACAD.Doc file that makes a call to VBA  to pop up a messagebox if the filename doesn't match the drawing number. I disabled it and it runs fine now in debug mode. I'm still wondering why the release version ran fine though.
Thanks Again
Valued Contributor
sszabo
Message 7 of 8 (279 Views)
07-31-2013 01:49 PM in reply to: GeeHaa
In debug mode you are running under msvsmon and your VBA code is running under acad.  You would probably have to use InvokeRequired around your Document object for this to work, again just guessing here.
GeeHaa
Message 8 of 8 (273 Views)
07-31-2013 01:57 PM in reply to: sszabo
I'm Sorry I meant AcadDoc.lsp file.
You are not logged in.
Ask the Community
