.NET
vinayan
Message 1 of 3 (360 Views)
Accepted Solution
Adding a Vertex to a closed Polyline
360 Views, 2 Replies
08-13-2013 04:30 AM
I have a method for inserting a vertex to a polyline. But this does not work for closed polylines for the case shown below. The code fails if the point is on the last edge of the polyline. Can someone look into it?
public void AddVertexOnPolyline(Point3d addPoint,Polyline editPolyline)
            Document acDoc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
            Editor pEditor = acDoc.Editor;
            int chk = 1;
            try
                for (int i = 0; (i <= (editPolyline.NumberOfVertices - 1)); i++)
                    double dist1 = editPolyline.GetDistAtPoint(addPoint);
                    double dist2 = editPolyline.GetDistAtPoint(editPolyline.GetPoint3dAt(i));
                    if ((editPolyline.GetDistAtPoint(addPoint) < (editPolyline.GetDistAtPoint(editPolyline.GetPoint3dAt(i)))) && chk != 0)
                        Point2d pnt2 = new Point2d(addPoint.X, addPoint.Y);
                        editPolyline.AddVertexAt(i, pnt2, 0, 0, 0);
                        chk = 0;
                        break;
            catch (System.Exception ex)
                throw;
*Expert Elite*
Jeff_M
Message 2 of 3 (315 Views)
Re: Adding a Vertex to a closed Polyline
08-15-2013 01:59 PM in reply to: vinayan
This works for me. Note that I chose a slightly different method of obtaining the index to add it to.
        public void AddVertexOnPolyline(Point3d addPoint, Polyline editPolyline)
            try
                Point3d ptOnPline = editPolyline.GetClosestPointTo(addPoint, false);
                double parm = editPolyline.GetParameterAtPoint(ptOnPline);
                editPolyline.AddVertexAt((int)System.Math.Floor(parm) + 1, pnt2, 0, 0, 0);
                throw;
Jeff_M, also a frequent Swamper
vinayan
Message 3 of 3 (265 Views)
08-20-2013 03:43 AM in reply to: vinayan
Jeff,
That worked out fine!
thanks a lot
You are not logged in.
Announcements
Need installation help?
Ask the Community
