.NET
Active Member
Message 1 of 2 (114 Views)
Adding a Construct via AddConstruct to my ACA project
114 Views, 1 Replies
04-03-2013 04:11 AM
I try to use the ACA .Net c# API to add a new construct to my project. Currently in 2013.
In the samples I've found one for basic Projetnavigator things, but adding a new construct isn't covered.
Is there any example out there which shows the steps?
THanks,
Tim
Active Member
Message 2 of 2 (90 Views)
Re: Adding a Construct via AddConstruct to my ACA project
04-03-2013 06:48 AM in reply to: THoffeller
ok, found the solution. Here's some code from my method:
ProjectFile info = newProjectFile(_proj);
info.DrawingFullPath =
Path.Combine(Path.GetDirectoryName(item.FullName), filename + ".dwg");
info.FileName =
Path.Combine(Path.GetDirectoryName(item.FullName), filename + ".xml");
info.FileCategory =
FileCategory.Document;
info.Name = filename;
info.Description = filename +
" autogenerated by CadDev ProjectStartup";
//info.Category = new DirectoryInfo(Path.GetDirectoryName(item.FullName)).Name;ProjectRegion reg = newProjectRegion();
reg.Add(
newRegionPair(System.Convert.ToUInt32(level.Id), System.Convert.ToUInt32(wing.Id)));
info.Regions.Add(reg);
//info.Id = level.Id;if (String.IsNullOrEmpty(dirconf.DrawingTemplate))
_proj.AddConstruct(info, _proj.Configuration.DocumentTemplate);
else
_proj.AddConstruct(info, dirconf.DrawingTemplate);
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
