.NET
Member
EasyA
Message 1 of 6 (334 Views)
Adding MText to AutoCAD using Visual Studio 2012
334 Views, 5 Replies
06-14-2013 08:54 AM
I'm relatively new to programming. I'm using Visual Studio 2012. The department is using AutoCAD 2013
I'm working on a program that adds the general notes to our drawings. The program does what I need it to do with one exception. The notes consist of multiple MText entries. When I click the "GENERAL NOTES" button to insert the notes, all the entries are compiled and inserted, but all at 0,0,0. I'm stuck at this point. Any help would be greatly appreciated.
Valued Mentor
fieldguy
Message 2 of 6 (316 Views)
Re: Adding MText to AutoCAD using Visual Studio 2012
06-14-2013 01:08 PM in reply to: EasyA
Are you setting the location property?
Dim myMText As New MText
myMText.Location = new point3d(x,y,z)
You will have to confirm the correct syntax.
Member
EasyA
Message 3 of 6 (291 Views)
06-15-2013 06:23 AM in reply to: EasyA
Thanks for your response. I was setting a location property but not by using a specific 3d point. I was using "middle top". Using a 3d point makes much more sense to me. Nothing like over looking the obvious. Do you have a method that will allow me to establish a specific space between each MText item?
Thanks again!
Valued Mentor
fieldguy
Message 4 of 6 (270 Views)
06-17-2013 07:21 AM in reply to: EasyA
I have not done that in code.  I often make manual changes using the property dialog,  The screen shot shows an example of how you might do it.  Any property with a "set" method *should* be available.
Member
EasyA
Message 5 of 6 (254 Views)
06-17-2013 08:11 AM in reply to: EasyA
Thanks...
I'm going to the office on Wednesday and will let you know how your solutions workout. Thanks again for your help.
Member
EasyA
Message 6 of 6 (224 Views)
06-19-2013 12:12 PM in reply to: EasyA
I wanted to let you know your solution works perfectly. I managed to work out the method for spacing the MText items using a value from the VBA program the new program is going to replace. At any rate, thanks for your help!!
You are not logged in.
Ask the Community
