.NET
Active Contributor
tcuneio
Message 1 of 4 (258 Views)
Adding Custom Classes to the DWG file
258 Views, 3 Replies
10-04-2013 02:33 PM
I'm new to .NET and am creating custom classes that I need to save to the DWG file.  I assume this is straightforward but have not found a way to do it.  I'm using VB.NET but can work with C++ examples as well.  Do I have to inherit from a DBObject class and override or is it possible to declare my own custom classes and somehow register them to DBObject?
Valued Mentor
gasty1001
Message 2 of 4 (248 Views)
Re: Adding Custom Classes to the DWG file
10-04-2013 03:44 PM in reply to: tcuneio
No sure what do you mean by custom classes, but if you are trying custom entities, the answer is NO, you can't do custom entities with .NET API, only C++ API.
Gaston Nunez
dgorsman
Message 3 of 4 (177 Views)
10-07-2013 11:24 AM in reply to: gasty1001
On the other hand, if this is simply about storing data there are all sorts of ways-and-means to getting that done.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Contributor
tcuneio
Message 4 of 4 (175 Views)
10-07-2013 11:30 AM in reply to: dgorsman
I'm now exploring ways to store the properties of objects in my classes in DBDictionaries and exect that will accomplish my purpose.  Thanks for the replies!
You are not logged in.
Ask the Community
