In 2014, you have trusted or approved folder search path. I'm able to add search path programmatically but I cannot found how to add trusted folder.
Anybody have a clue?
André
Solved by andred. Go to Solution.
Solved by BlackBox_. Go to Solution.
If I am understanding you correctly, you're after this, found in TRUSTEDPATHS documentation:
AutoCAD Online Help, TRUSTEDPATHS (System Variable)
- When TRUSTEDPATHS includes a folder that ends with \... (backslash and three dots), all of its subfolders are also trusted.
"How we think determines what we do, and what we do determines what we get."
Thank you,
I was trying to add trusted folder using Application.Preferences and I was looking for Files.SupportPath equivalent to trustedpaths. I didn't know there is a system variable. I will use this variable to add trusted path.
André
You're welcome; I'm happy to help.
Don't forget to please mark the post as solution.
Cheers
