.NET
184 Views, 4 Replies
Add method
Is there a simple way to initialize an array list with several items rather
than using the add method for each item? In the following example it would
be nice to add all items with one add call.
fa_FrenchDoors.Add("FDOR")
fa_FrenchDoors.Add("FPAR")
fa_FrenchDoors.Add("FAES")
fa_FrenchDoors.Add("FAEL")
fa_FrenchDoors.Add("FAED")
fa_FrenchDoors.Add("FAER")
fa_FrenchDoors.Add("BDE2")
4 REPLIES 4
ArrayList a = new ArrayList(new string[] {"a", "b", "c"});
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Dale Levesque" wrote in message news:4984952@discussion.autodesk.com...
Excellent.
"Tony Tanzillo" wrote in message
news:4985046@discussion.autodesk.com...
Just having abit of trouble converting to VB .net though : ) I'm assuming
this is C# Tony?
According to reflector:
Dim a As New ArrayList( New String() {"a", "b", "c"} )
"Dale Levesque" wrote in message news:4985110@discussion.autodesk.com...
this is C# Tony?
”Boost
