.NET
Add many paths into loader key
7 REPLIES 7
Message 1 of 8
ditran7577
870 Views, 7 Replies
Hi everybody,
I try to add some paths into registry value as picture:
Is there any way to do this?
Thanks for any help.
7 REPLIES 7
Message 2 of 8
in reply to: ditran7577
I am afraid that multipath is not valid for 'LOADER' key. Better to create individual key for test2.dll
Message 3 of 8
StephenPreston
The usual way to do this is to create a 'loader DLL' that you set the demand load registry keys for. This loader DLL then takes care of loading any other required modules. For AutoCAD 2012 and above you should also look at the AutoLoader feature as a simple way to define demand load settings for your plugins.
Cheers,
Stephen Preston
Autodesk Developer Network
Message 4 of 8
ditran7577
Thanks for the comments. But I have many dll files, so I don't want to create many keys in registry.
Hi Stephen,
Can you tell more clearly or provide any links to learn?
Message 5 of 8
jeff
As Stephen mentioned AutoLoader and a "Loader dll" I use AutoLoader to load a assembly that has no other references other than AutoCAD & BCL.
It just knows to find a file in same location that contains paths to network locations which contains another file for instructions.
The instructions tell it to copy, copy if file is newer, delete, include subdirectories, etc..... files inside its .bundle folder,
and load any assemblies, cui, etc... that needs to be loaded.
Also update the file used to find its location if needed to move.
You can also find your answers @ TheSwamp
Message 6 of 8
StephenPreston
The handout for this AU class is probably a good starting point - https://events.au.autodesk.com/connect/sessionDetail.ww?SESSION_ID=2142. Otherwise, search for 'Autoloader' on the ADN DevBlog, Kean's Through the Interface blog, this forum, or TheSwamp.
Cheers,
Stephen Preston
Message 7 of 8
ditran7577
in reply to: StephenPreston
Thank Stephen, but I cannot access to provided link.
Message 8 of 8
The point on the end is too much, should be:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
