.NET
Add entities to new block
7 REPLIES 7
Message 1 of 8
MRiemenCAD
3865 Views, 7 Replies
Working with making blocks from existing entities in a file. I've run into problems with iterating through the entities within a selection set and writing them to my new blocktablerecord. How do I take those items from my selection set and add them to this new block? All thoughts and help are appreciated.
Tags (3)
7 REPLIES 7
Message 2 of 8
dan.glassman
in reply to: MRiemenCAD
You can:
  • Manually create the new BlockTableRecord and BlockTable.Add() it, then
  • Database.DeepCloneObjects() into your new BlockTableRecord
or:
  • Database.WBlock(ObjectIdCollection,Point3d) to create a new, temporary database containing your objects, then
  • Database.Insert(string, Database, bool) to create your new BlockTableRecord
or (if you don't mind deleting that the existing entities are _moved_ to the new BlockTableRecord rather than copied):
  • BlockTableRecord.AssumeOwnershipOf()
Message 3 of 8
MRiemenCAD
in reply to: dan.glassman
I like the "AssumeOwnershipOf" route that you suggest. When I use this on the selection set I'm told that the set  cannot be converted into and ObjectIDCollection. May this I'm missing a simple step in working with selection sets. Is there an easy way to take the objects from the selection set, create a suitable IDCollection and then pass that collection to the "AssumeOwnershipOf" method?
Matt
Message 4 of 8
dan.glassman
Yup.  The ObjectIdCollection constructor can take an ObjectId array as an argument, which is what SelectionSet.GetObjectIds() provides.
Put another way...
Dim ids as ObjectIdCollection = New ObjectIdCollection(sset.GetObjectIds)
Message 5 of 8
Hallex
Something like this
Just a hint starting the new thread you will be able to get a much more explanations
because of hiding your question at the end of thread
Imports System
Imports System.Text
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class TesterCommands
    <CommandMethod("bobo", CommandFlags.UsePickSet)> _
    Public Sub MakeBlockFromSelection()
        Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Using docloc As DocumentLock = doc.LockDocument
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Try
                    Dim pso As New PromptSelectionOptions()
                    pso.MessageForRemoval = vbLf & " >>  Nothing selected...."
                    pso.MessageForAdding = vbLf & "  >>  Select objects >> "
                    pso.AllowDuplicates = False
                    pso.SingleOnly = True
                    Dim res As PromptSelectionResult = ed.GetSelection(pso)
                    If res.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim ids As ObjectId() = res.Value.GetObjectIds()
                    If ids.Length = 0 Then
                        Return
                    End If
                    Dim ppo As New PromptPointOptions(vbLf & "Pick insertion point for newly created block >>")
                    Dim pres As PromptPointResult = ed.GetPoint(ppo)
                    If pres.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim ip As Point3d = pres.Value
                    Dim bt As BlockTable = DirectCast(db.BlockTableId.GetObject(OpenMode.ForWrite), BlockTable)
                    Dim newname As String = "MyCoolBlock"
                    If bt.Has(newname) Then
                        ed.WriteMessage(vbLf & "Block ""{0}"" already exist", newname)
                        Return
                    End If
                    Dim bids As New ObjectIdCollection()
                    For Each eid As ObjectId In ids
                        bids.Add(eid)
                    Next
                    acApp.SetSystemVariable("clayer", "0")
                    acApp.SetSystemVariable("cecolor", "bylayer")
                    Dim nbtr As New BlockTableRecord()
                    bt.Add(nbtr)
                    nbtr.Name = newname
                    nbtr.Origin = ip
                    nbtr.BlockScaling = BlockScaling.Uniform
                    nbtr.Explodable = True
                    tr.AddNewlyCreatedDBObject(nbtr, True)
                    Dim map As New IdMapping()
                    db.DeepCloneObjects(bids, nbtr.ObjectId, map, False)
                    Dim coll As New ObjectIdCollection()
                    For Each pair As IdPair In map
                        If pair.IsPrimary Then
                            Dim ent As Entity = DirectCast(tr.GetObject(pair.Value, OpenMode.ForWrite), Entity)
                            If ent IsNot Nothing Then
                                ent.Layer = "0"
                                ent.ColorIndex = 0
                                If (TypeOf (ent) Is AttributeDefinition) Then
                                    Dim att As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                                    att.LockPositionInBlock = True
                                End If
                                '<-- color byblock
                                coll.Add(ent.ObjectId)
                            End If
                        End If
                    Next
                    nbtr.AssumeOwnershipOf(coll)
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(vbLf + ex.Message + vbLf + ex.StackTrace)
                End Try
            End Using
        End Using
    End Sub
End Class
~'J'~
Message 6 of 8
MRiemenCAD
in reply to: Hallex
Thanks for your post. I thought that your previous comment to the original string was close to the sollution i was after so i tried targetting my question. Smiley Happy
thanks for you reply. It worked great. I'll study through it to see what I missed on my own.
regards,
matt
Message 7 of 8
Hallex
You're welcome
 Cheers 🙂
Oleg
~'J'~
Message 8 of 8
riley-ge
in reply to: Hallex
It's a good solution to my problem. Thanks!
”Boost
