.NET
Add drawings to active project
1 REPLY 1
353 Views, 1 Reply
Hello everyone,
I encounter a problem that I do not understand. I created a little C# routine for Autocad Electrical (2011 and 2012) which adds some drawings to the current project with the following command:
(c:ace_add_dwg_to_project  dwg2add  paramlst)
This mehtod works perfectly. With the parameter list you can set the Section, Sub-Section and Descriptions of the page properties, exactly what I want.
When I start the routine, I check which project is active. If the wrong project is active, I activate the appropiate project with the following command:
(c:wd_makeproj_current  wdpfnam)
So, when I want to add drawings to project A and project B is active at the start of the routine, I activate project A and the drawings are added.
The problem:
When I want to add drawings to project A and this project is already active, the drawings are not added to the project. The method mentioned above to add drawings returns nill, which means a failure.
Why is this happening? Is this a bug of Autocad?
I already tried to always activate the project I want to add drawings to, but that doensn't matter.
Can anyone help me with this problem?
Thanks in advance.
1 REPLY 1
wayne.brill
in reply to: 110000474593
I see this same issue is being discussed on this post. .
http://forums.autodesk.com/t5/AutoCAD-Electrical/Add-drawings-to-active-project/td-p/4672543
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
”Boost
