Hey Mark,
I'm no Tony, but maybe I can help.
You are transforming a database resident object with each move of the mouse.
Your jig should be working with non db resident objects. Check out this
example http://www.theswamp.org/index.php?topic=8198.0, just note that I
never did finish this to my liking. Run it and move your mouse out of the
drawing area to see what I mean.
However, since you are targeting 2007, you can use the overloaded Drag
method that wraps acedDragGen().
public class EntityDragger
private Point3d m_basePoint;
[CommandMethod("dragSS")]
public void SsDragger()
Editor currentEditor = acadApp.DocumentManager.MdiActiveDocument.Editor;
//Create a new selection set options object
PromptSelectionOptions ssOptions = new PromptSelectionOptions();
ssOptions.AllowDuplicates = true;
ssOptions.MessageForAdding = "Select objects to copy: ";
//Get a selection from the user
PromptSelectionResult ssResult = currentEditor.GetSelection(ssOptions);
if (ssResult.Status != PromptStatus.OK)
return;
//Get a base point from the user
PromptPointResult pointResult = currentEditor.GetPoint("\nSelect base point:
if (pointResult.Status != PromptStatus.OK)
return;
m_basePoint = pointResult.Value;
//Initiate the drag callback delegate
DragCallback dragCallbackDelegate = this.FollowCursor;
//Start the drag operation
PromptDragOptions dragOptions = new PromptDragOptions(ssResult.Value,
"\nSelect destination point: ", dragCallbackDelegate);
PromptPointResult destinationPointResult = currentEditor.Drag(dragOptions);
if (destinationPointResult.Status != PromptStatus.OK)
return;
//Determine the final displacement matrix
Matrix3d transMat =
Matrix3d.Displacement(m_basePoint.GetVectorTo(destinationPointResult.Value));
//transform the ss to the new location
this.TransformSelectionSet(ssResult.Value, transMat);
//DragCallback Delegate
public SamplerStatus FollowCursor(Point3d currentPoint, ref Matrix3d
transMat)
transMat = Matrix3d.Displacement(m_basePoint.GetVectorTo(currentPoint));
return SamplerStatus.OK;
Also note that they fixed the GetVectorTo() method in 07; this:
Vector3d displacementVector =
currentCursorPosition.GetVectorTo(previousCursorPosition);
displacementVector = displacementVector.MultiplyBy(-1);
can be replaced with this:
previousCursorPosition.GetVectorTo(currentCursorPosition);
p.s. - I just saw that you posted over in the swamp. I'll post this code
there so you can see it with some formatting.
Bobby C. Jones
"Mark Johnston" wrote in message
news:5249253@discussion.autodesk.com...
Thanks Nathan,
I did see your VB example. I was hoping to do this in C# but I may just
build on your example. I agree that checking for amount of movement should
be unnecessary. It was something I did just to see what would happen.
(hoping for a clue)
Maybe a reader with experience in C# can point me in the right direction.
(hint Tony)
wrote in message news:5248434@discussion.autodesk.com...
I can't see anything wrong with your code. I haven't tried yours but I have
a VB block insert example that does not twitch. Checking a tolerance should
be unnecessary.
Regards - Nathan
