.NET
.NET
Valued Contributor
Ertqwa
Message 1 of 4 (436 Views)
Active Document - eNotFromThisDocument error
436 Views, 3 Replies
01-14-2012 03:33 PM
Hello Forum,
the following code gives me an eNotFromThisDocument error:
[LispFunction("MyFunction")]
public ResultBuffer MyFunction(ResultBuffer rbParameter)
    objDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(strPath, false);
    if (!objDocument.IsReadOnly)
        using (objDocumentLock = objDocument.LockDocument())
            Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = objDocument;
            objDocument.Database.TileMode = true; //  = eNotFromThisDocument.
        objDocument.CloseAndSave(strPath);
        objDocument.Dispose();
 I think it is because the Editor does not get linked to the newly opened drawing. In other words, I can not change tilemode of objDocument, because the drawing from which I called this function is still the active/current drawing. How can I tell AutoCAD that objDocument should be the active/current drawing, so I can change the tilemode, and use Editor functionality, such as SendString()?
Thank you.
Alfred.NESWADBA
Message 2 of 4 (423 Views)
Re: Active Document - eNotFromThisDocument error
01-15-2012 12:39 AM in reply to: Ertqwa
as a guess: in LISP you get lost if the document changed as LISP-code it runs document-based. If you start a LISP in A.DWG you can start to load B.DWG but the lisp-code will not continue in B.DWG.
That you load a drawing and make the this other drawing active within a LISP-function may be the source of the problem.
- alfred -
Alfred NESWADBA
Hallex
Message 3 of 4 (403 Views)
01-15-2012 12:01 PM in reply to: Ertqwa
See if this works for yoy, tested on A2010
<code>
Document doc = acadApp.DocumentManager.MdiActiveDocument;
string strPath = .....;
using (DocumentLock objDocumentLock = doc.LockDocument())
Document objDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(strPath, false);
using (DocumentLock pDocumentLock = objDocument.LockDocument())
Database pdb = HostApplicationServices.WorkingDatabase;
if (pdb.TileMode == true)
pdb.TileMode = false;
//Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("ctab", "Floor Plan");//debug only
return new ResultBuffer(new TypedValue((int)LispDataType.Nil));
</code>
Valued Contributor
Ertqwa
Message 4 of 4 (379 Views)
01-16-2012 12:29 PM in reply to: Hallex
Hello Hallex, with your code I no longer get the "eNotFromThisDocument" error, but that is because "HostApplicationServices.WorkingDatabase" returns the database of the drawing from which I run the lisp function, and not the database from the drawing that I open with "DocumentManager.Open". Thank you for the response.
