.NET
Activating drawing screen after clicking button on a toolstrip on a toolpalette
6 REPLIES 6
tanerpro
1562 Views, 6 Replies
I  am developing a custom toolpalette, with a toolstrip and buttons on it. The botton asks user to select a point on the screen. But when the button is pressed it gets focus and tu user has to first click on the screen first to activate it and another click to select the point. This is annoying. I tried all of below but can not figure it out. How can i do it?
regards,
            BringWindowToTop(Acad.HWND32)
            BringWindowToTop(Doc.HWND32)
            BringWindowToTop(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle.ToInt32)
            AppActivate(Acad.HWND32)
            AppActivate(Doc.HWND32)
            AppActivate(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle.ToInt32)
           Setfocus.....
6 REPLIES 6
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
Thanks but didn't work, as seen in the attachments, the marked button always stays pressed, unless i click anywhere on autocad caption, menus, screen, the button remains focused, maybe we have to make it lost focus.
Alfred.NESWADBA
in reply to: tanerpro
does that help:
      <DllImport("user32.dll")> _
      Private Shared Function SetFocus(ByVal hwnd As System.IntPtr) As System.IntPtr
      End Function
And to call it:
      Call SetFocus(ApplicationServices.Application.DocumentManager.MdiActiveDocument.Window.Handle)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
That suggestion works with a regular Button, but I didn't notice that you were using a ToolStripButton, which requires special measures.
Here's a solution I've used for that. You can call the AsyncSetFocusToDwgView() just before you call GetPoint(), and see if that works.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Internal;
namespace AcApHelpers
   public static class AcApUtils
      public static void AsyncSetFocusToDwgView()
         AsyncHelper.BeginInvoke( () =>
   public static class AsyncHelper
      public static void BeginInvoke( Action action )
         if( action == null )
            throw new ArgumentNullException( "action" );
         new IdleInvoke( action );
      class IdleInvoke
         Action action;
         public IdleInvoke( Action action )
            this.action = action;
            Application.Idle += onIdle;
         void onIdle( object sender, EventArgs e )
            Application.Idle -= onIdle;
            action();
tanerpro
in reply to: Alfred.NESWADBA
Alfred, it didn't work. Whatever I do the toolstripbutton stays pressed, if i click anywhere else, even the palette itself or autocad menus, screen,... , it loses focus but i can't figure it out. I tried to set focus on another object on the palette after the button click event but didn't work. What am i doing wrong? Nobody using toolpalette or toolstripbuttons?
DiningPhilosopher sorry but I am using vb.net and at the very beginnig, I can't try it. But thanks.
You can convert the code to VB.NET using an online converter or a Visual Studio Extension
”Boost
