AcdbBlockTable::getAt() in .NET?
The docs says:
"Autodesk.AutoCAD.DatabaseServices.BlockTable Class
This .NET class wraps the AcDbBlockTable ObjectARX class."
But where's the funtion getAt?
Is there another function that finds a block with a specific name, or do i
have to iterate the blocktable myself?
/Matt
The default indexer for all SymbolTable based classes
returns elements given the name as the string index.
However, beware that it returns *erased* entries,
which could prevent you from accessing a non-erased
entry that has the same name as an erased entry,
if the erased entry appears first in the table.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Matt" wrote in message news:4990996@discussion.autodesk.com...
The docs says:
/Matt
