.NET
Accessing entities on paperspace Layouts
2 REPLIES 2
GilesPhillips
2182 Views, 2 Replies
I'm trying to rewrite some old VBA code into VB.net (which I'm not even Novice level yet), and I'm stumped on what would be a fairly simple principle (in VBA)..
For Each BlockDef in ThisDrawing.blocks
   If Left(BlockDef.name, 12) = "*Paper_Space" then
      Select Case True
         Case BlockDef.Layout.Name Like "*Test*"
            blah blah
      End Select
Next
Essentially conditional manipulation of paperspace elements depending on the layout name.
 The following fragment allows me to recurse through entities in paperspace, but I've no idea which layout tab..
Dim BlkPaperSpc As BlockTableRecord = ScanTrans.GetObject(BlkTab _
(BlockTableRecord.PaperSpace), OpenMode.ForWrite)
For Each AcObjId As ObjectId In BlkPaperSpc
   Dim PspaceObj As String = AcObjId.ObjectClass.Name
Next
What I need to do is to be able to identify a type of object (a table), confirm it's location, delete it and replace it with another one, depending on which layout tab it's on.
Any pointers or tips for the complete novice??
G
ACad, MEP, Revit, 3DS Max
2 REPLIES 2
Hallex
in reply to: GilesPhillips
This is not the best solution but I hope
it will to get you started
       ''      get the real block name.        ''
        Public Shared Function EffectiveName(tr As Transaction, bref As BlockReference) As String
            Dim btr As BlockTableRecord = Nothing
            If (bref.IsDynamicBlock) Or (bref.Name.StartsWith("`*U", StringComparison.InvariantCultureIgnoreCase)) Then
                btr = TryCast(tr.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord)
            Else
                btr = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
            Return btr.Name
        End Function
        <CommandMethod("cblk")> _
        Public Sub iterateThroughLayouts()
            Dim layts As New List(Of String)
            Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim blkdict As New Dictionary(Of ObjectId, String())
            Try
                Dim tr As Transaction = db.TransactionManager.StartTransaction
                Using tr
                    Dim ldict As DBDictionary = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead)
                    For Each dicent As DBDictionaryEntry In ldict
                        Dim lay As Layout = CType(dicent.Value.GetObject(OpenMode.ForRead), Layout)
                        Dim layname As String = lay.LayoutName
                        ''do your stuffs in the every layout
                        If layname <> "Model" Then
                            Dim btr As BlockTableRecord = tr.GetObject(lay.BlockTableRecordId, OpenMode.ForRead)
                            For Each id As ObjectId In btr
                                Dim ent As Entity = tr.GetObject(id, OpenMode.ForRead, False)
                                If TypeOf (ent) Is BlockReference Then
                                    'get block instance
                                    Dim bref As BlockReference = DirectCast(ent, BlockReference)
                                    'get block name
                                    Dim blkname = EffectiveName(tr, bref)
                                    ' get block instance owner
                                    blkdict.Add(bref.ObjectId, New String() {blkname, layname})
                                    'we have to gather all desired values to Dictionary (of string, string())
                            Next
                    Next
                    tr.Commit()
                End Using
                'display info in the command line after
                For Each kvp As KeyValuePair(Of ObjectId, String()) In blkdict
                    ed.WriteMessage(vbLf + "{0}   {1}   {2}" + vbLf, kvp.Key, kvp.Value(0), kvp.Value(1))
                Next
            Catch ex As System.Exception
                acApp.ShowAlertDialog(Environment.NewLine + ex.Message + Environment.NewLine + ex.StackTrace)
            End Try
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
GilesPhillips
in reply to: Hallex
Hi, Thanks for the code fragment - unfortunately I've not had time today to read through it and understand it completely, but I didn't want your effort to go without response.
I'm sure I'll be back with more questions, hopefully on other topics 🙂
G
”Boost
