I have attached a DOC file that shows exactly the Plant 3D interface and the reference to the FIELD that I am after. If someone can point me in the right direction, I want to access a FIELD (specifically the AREA field in an AutoCAD PLANT 3D drawing), and then set that FIELD value.
Solved by philippe.leefsma. Go to Solution.
'insertion du bloc !!! Dim RefBloc As BlockReference = Nothing Dim BlocT As BlockTable Dim CollObject As New Collection tr = db.TransactionManager.StartTransaction Try Dim ang As Object Dim CoteA, CoteB As Double Dim pointUcs As New Point3d(0, 500, 0) Dim pointdepart = Point3d.Origin pointdepart = pointdepart.TransformBy(Ed.CurrentUserCoordinateSystem.Inverse) pointUcs = pointUcs.TransformBy(Ed.CurrentUserCoordinateSystem.Inverse) CoteA = pointUcs.X - pointdepart.X CoteB = pointUcs.Y - pointdepart.Y Try ang = Math.Atan(CoteA / CoteB) Catch ex As Exception ang = 0 End Try 'si Coté B négatif alors angle >180 et <0 --> rotation de 180 à faire If CoteB < 0 Then ang = ang - Math.PI 'Le bloc est à l'unité cm par défaut Dim Unite As Double Dim obj As Object = acApp.GetSystemVariable("INSUNITS") Select Case System.Convert.ToInt16(obj) Case 4 : Unite = 10 'mm Case 5 : Unite = 1 'cm Case 6 : Unite = 0.01 'm Case Else : Unite = 1 End Select BlocT = tr.GetObject(db.BlockTableId, OpenMode.ForRead) Dim Bloc As BlockTableRecord 'sélection de la zone d'insertion (Objet/papier) '1 si objet / 0 si papier Dim OkEspaceObjet As Integer = acApp.GetSystemVariable("TILEMODE") '1 si espace papier / 2 si dans Fenetre Dim OkEspacePapier As Integer = acApp.GetSystemVariable("CVPORT") If OkEspacePapier = 1 Then 'Espace Papier Bloc = tr.GetObject(BlocT.Item(BlockTableRecord.PaperSpace), OpenMode.ForWrite) Unite = 0.5 '(car bloc en cm et papier en mm) Else 'Espace Objet ou Fenetre dans Papier Bloc = tr.GetObject(BlocT.Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite) End If RefBloc = New BlockReference(PointDebutTableau, DefBloc.ObjectId) RefBloc.Layer = "0" RefBloc.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 256) RefBloc.ScaleFactors = New Scale3d(Unite, Unite, Unite) RefBloc.Rotation = ang Bloc.AppendEntity(RefBloc) tr.AddNewlyCreatedDBObject(RefBloc, True) Dim txt As String = "" Dim objID As ObjectId Dim vpIdVal As Long 'Dim fieldEval As FieldEvaluationStatusResult = FieldObj.EvaluationStatus 'If fieldEval.Status <> FieldEvaluationStatus.Success Then ' Ed.WriteMessage(vbCrLf & "FieldEvaluationStatus {0} - Message: {1}", fieldEval.Status, fieldEval.ErrorMessage) ' Exit Sub 'Else 'gestion des attributs Dim Index As Integer Dim FieldObj As Field Dim btAttRec As BlockTableRecord btAttRec = tr.GetObject(DefBloc.ObjectId, OpenMode.ForRead) Dim idAtt As ObjectId For Each idAtt In btAttRec Dim ent As Entity ent = tr.GetObject(idAtt, OpenMode.ForRead) If TypeOf ent Is AttributeDefinition Then Dim attDef As AttributeDefinition attDef = CType(ent, AttributeDefinition) Dim attRef As New AttributeReference attRef.SetAttributeFromBlock(attDef, RefBloc.BlockTransform) 'détection de l'att. If attRef.Tag.Contains("NomXref") = True Then Index = CInt(attRef.Tag.Replace("NomXref", "")) txt = DataGridViewT.Rows.Item(Index).Cells(Enum_DataG.Handle).Value objID = db.GetObjectId(False, New Handle(Int64.Parse(txt, Globalization.NumberStyles.AllowHexSpecifier)), 0) vpIdVal = Convert.ToInt64(objID.ToString.Substring(1, objID.ToString.Length - 2)) FieldObj = New Field() FieldObj.EvaluationOption = FieldEvaluationOptions.Automatic FieldObj.SetFieldCode(String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%).Name \f ""%tc4"">%", vpIdVal)) attRef.SetField(FieldObj) CollObject.Add(attRef) ElseIf attRef.Tag.Contains("CheminXref") = True Then Index = CInt(attRef.Tag.Replace("CheminXref", "")) txt = DataGridViewT.Rows.Item(Index).Cells(Enum_DataG.Handle).Value objID = db.GetObjectId(False, New Handle(Int64.Parse(txt, Globalization.NumberStyles.AllowHexSpecifier)), 0) vpIdVal = Convert.ToInt64(objID.ToString.Substring(1, objID.ToString.Length - 2)) FieldObj = New Field() FieldObj.EvaluationOption = FieldEvaluationOptions.Automatic If RadioButtonNomFichierPath.Checked = True Then 'Nom + Fichier FieldObj.SetFieldCode(String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%,1).Path \f ""%tc4"">%", vpIdVal)) Else 'Nom Fichier uniquement FieldObj.SetFieldCode(String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%,1).Path \f ""%fn6"">%", vpIdVal)) End If attRef.SetField(FieldObj) CollObject.Add(attRef) End If RefBloc.AttributeCollection.AppendAttribute(attRef) tr.AddNewlyCreatedDBObject(attRef, True) End If Next Catch ex As Exception MsgBox("Erreur à l'insertion du bloc", MsgBoxStyle.Critical & vbOKOnly, "Erreur système dans ClassFichier.GestionBlocTableau") Finally tr.Commit() tr.Dispose() End Try '-->V2.0.0.1 'Regen pour générer le remplissage des champs. #If _AcadVer_ = 2010 Then GestionAUTOCAD.LigneCommandeImmediate("_regenall") #Else acApp.DocumentManager.MdiActiveDocument.Editor.Regen() #End If '<--V2.0.0.1
here a sample code for inserting a blocreference and set a attribut with à field.
te attribut show the name of a Xref inserted in the dwg.
Sorry i am french so my annotation is in my language.
You cant copy/past this code in your vb app. but you cade use the part of the use of field.
Thanks AubelecBE, I will take a look at this today and see what I can do. At first glance, you have pointed to an attribute changed to a field, while I am after the field of the drawing itself, much like maybe going after the Sheet Set Manager field. But nonetheless, maybe I can make the jump over.
Check out my post, it illustrates how to find all fields in a drawing:
http://adndevblog.typepad.com/autocad/2014/07/how-to-find-all-fields-in-a-drawing.html
Philippe.
