.NET
matus.brlit
Message 1 of 3 (341 Views)
Access drawing from new thread
341 Views, 2 Replies
02-17-2012 12:07 AM
I found out, that you can't read AcApp.DocumentManager.MdiActiveDocument from a new thread, so I was passing the reference to the document to every method that needed to use it
But then I found out, that HostApplicationServices.WorkingDatabase allows me to access the database from a new thread.
So I'm wondering, is there any other difference, whether I access the database using AcApp.DocumentManager.MdiActiveDocument.Database or HostApplicationServices.WorkingDatabase ?
And is there some way for thread-sefe access to the active document?
Board Manager
StephenPreston
Message 2 of 3 (312 Views)
Re: Access drawing from new thread
02-18-2012 09:17 AM in reply to: matus.brlit
Hi Matus,
AutoCAD APIs are not multithreaded safe, so you should only access the AutoCAD APIs from your main thread. This is documented in the ObjectARX helpfiles. If you want to process data on another thread, its best to extract what you need on your main thread, send it to your worker thread, and then send the result back to the main thread if you need to send something back to AutoCAD.
But to answer your question on Databases, HostApplicationServices.WorkingDatabase and MdiActiveDocument.Database will (in general) return the same Database.
Cheers,
Stephen
Cheers,
Stephen Preston
Autodesk Developer Network
matus.brlit
Message 3 of 3 (287 Views)
02-19-2012 11:11 PM in reply to: StephenPreston
Thanks for the clarification on databases.
But can you also explain why HostApplicationServices.WorkingDatabase is threadsafe? At least it works for me.
You are not logged in.
Ask the Community
