.NET
Active Contributor
JF_005
Message 1 of 7 (372 Views)
Access BlockPropertiesTable from a BlockReference
372 Views, 6 Replies
09-19-2012 09:23 PM
I use a block entity that contains a BlockPropertiesTable (not a LookupTable) with dimension constraints and user parameters. I managed to find sample code on how to get the current value of these parameters (
AssocNetwork class), but I don't know how to access the ObjectId of the BlockPropertiesTable from my BlockReference. This would be useful to get a list of all values available for a specific parameter in the table for example.
Any help would be much appreciated.
ADN Support Specialist
philippe.leefsma
Message 2 of 7 (304 Views)
Re: Access BlockPropertiesTable from a BlockReference
09-28-2012 04:28 AM in reply to: JF_005
Hi JF,
Can you please provide a minimal sample file containing your block, so I can take a closer look.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Active Contributor
JF_005
Message 3 of 7 (297 Views)
09-28-2012 06:17 AM in reply to: philippe.leefsma
Here you go. This is a pipe fitting tee. The primary column of the BlockPropertiesTable lets you chose the fitting nominal pipe size (3/4"-NPT for example).
I know I can change the BlockReference property value (current row to display) like this:
For Each prop As DynamicBlockReferenceProperty In br.DynamicBlockReferencePropertyCollection
    If prop.PropertyName.ToUpper() = "BLOCK TABLE1" Then
        prop.Value = CShort(2)
    End If
Next
 But this does not give me any info about the the rows and columns of the BlockPropertiesTable entity.
Thanks in advance for your help! :smileyhappy:
philippe.leefsma
Message 4 of 7 (293 Views)
09-28-2012 06:32 AM in reply to: JF_005
The API for dynamic block is not very powerful, accessing parameters is basically all you can do, so the information you are looking for is probably not accessible directly.
You may want to check the following post, it exposes an approach to discover additional properties, but it involves some personal research on your side:
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html?cid...
I hope it helps,
Philippe.
Philippe Leefsma
Active Contributor
JF_005
Message 5 of 7 (292 Views)
09-28-2012 06:33 AM in reply to: philippe.leefsma
By the way, I code in VB but I don't mind if the solution is in VB or C#. (I'm used to convert from C# to VB)
Active Contributor
JF_005
Message 6 of 7 (288 Views)
09-28-2012 06:34 AM in reply to: philippe.leefsma
Thank you, i'll check this out.
Valued Mentor
DiningPhilosopher
Message 7 of 7 (266 Views)
09-28-2012 05:37 PM in reply to: JF_005
And, in case the graphics that were not lifted from the original article might help, here's a link:
http://forums.autodesk.com/t5/NET/Dynamic-block-question/m-p/2640949#M18132
You are not logged in.
Ask the Community
