.NET
Active Contributor
Message 1 of 5 (128 Views)
Acces info from an existing palette
128 Views, 4 Replies
08-20-2013 04:07 PM
I want to run a code something like this:
for each ctrl in autocad window
if type of ctrl is palette then
msgbox (Ctrl.name)
end if
next
Practically I want to read the info existing from a palette that is loaded by CADWORX
ADN Support Specialist
Message 2 of 5 (115 Views)
Re: Acces info from an existing palette
08-20-2013 05:34 PM in reply to: dancalgary
i don't think there is a way to iterate *all* palette windows in AutoCAD using .NET. The only way that might be possible is to use MFC to iterate the CControlbar objects... Something like this:
// loop through the control bars, loop 1000
for (UINTcount=0; count<1000; ++count)
CControlBar *controlBar = acedGetAcadFrame()->GetControlBar(count);
if (controlBar == NULL)
  continue;
// convert from ControlBar to CAdUiPaletteSet
CAdUiPaletteSet *dockControlBar = DYNAMIC_DOWNCAST(CAdUiPaletteSet, controlBar);
// if ok
if (dockControlBar != NULL)
 do something
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Active Contributor
Message 3 of 5 (83 Views)
08-21-2013 07:25 AM in reply to: fenton.webb
thanks for the answer
mfc looks is the way but unfortunatelly for me i do not know how to implement it.
i was trying to read the text from a combobox on that palette and i don't know what is the name of that palette that is brought in by Cadworx.
*Expert Elite*
dgorsman
Message 4 of 5 (71 Views)
08-21-2013 08:39 AM in reply to: dancalgary
My advice, read the PRJ content directly using something from System.XML namespace.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Message 5 of 5 (66 Views)
08-21-2013 08:54 AM in reply to: dgorsman
Once you have found the PaletteSet window, you can enumerate the controls to find the CCombobox. Use the EnumChildWindows() in the Win32 SDK
Fenton Webb
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
