.NET
Acces info from an existing palette
4 REPLIES 4
dancalgary
372 Views, 4 Replies
I want to run a code something like this:
for each ctrl in autocad window
if type of ctrl is palette then
msgbox (Ctrl.name)
end if
next
Practically I want to read the info existing from a palette that is loaded by CADWORX
4 REPLIES 4
fenton.webb
in reply to: dancalgary
i don't think there is a way to iterate *all* palette windows in AutoCAD using .NET. The only way that might be possible is to use MFC to iterate the CControlbar objects... Something like this:
// loop through the control bars, loop 1000
for (UINTcount=0; count<1000; ++count)
CControlBar *controlBar = acedGetAcadFrame()->GetControlBar(count);
if (controlBar == NULL)
  continue;
// convert from ControlBar to CAdUiPaletteSet
CAdUiPaletteSet *dockControlBar = DYNAMIC_DOWNCAST(CAdUiPaletteSet, controlBar);
// if ok
if (dockControlBar != NULL)
 do something
Fenton Webb
AutoCAD Engineering
dancalgary
in reply to: fenton.webb
thanks for the answer
mfc looks is the way but unfortunatelly for me i do not know how to implement it.
i was trying to read the text from a combobox on that palette and i don't know what is the name of that palette that is brought in by Cadworx.
dgorsman
My advice, read the PRJ content directly using something from System.XML namespace.
fenton.webb
in reply to: dgorsman
Once you have found the PaletteSet window, you can enumerate the controls to find the CCombobox. Use the EnumChildWindows() in the Win32 SDK
Fenton Webb
AutoCAD Engineering
”Boost
