.NET
Distinguished Contributor
alex_b
Message 11 of 14 (376 Views)
Re: AcadSelectionSet.AddItems(AcadBlockReference.Explode())
09-04-2012 08:18 PM in reply to: Hallex
Hallex
I can't seem to find a CloneObjects() method in Interop.
If you mean CopyObjects(), all I could find about it is some examples of its use for copying objects between databases and no documentation (also the examples are in VB, knowledge of which I have less than zero).
I understand that there is a problem copying entities from a block definition.
Maybe the (ugly) solution would be
[insert the block; explode it; add the exploded entities to the selection set; wblock the selection set; erase the exploded entities]
Could you help?
alex
Hallex
Message 12 of 14 (370 Views)
09-04-2012 11:08 PM in reply to: alex_b
I can't test this code on A2004,
just tested them on my A2010, all is Ok here
Try again:
       [CommandMethod("copydef")]
       public static void CopyBlockDefToDwg()
           MessageBox.Show("Wait...");
           // change file names to suit:
           string sourcePath = @"C:\Test\WorkingDrawing2.dwg";
           string tempPath = @"C:\Test\atest.dwg";
           AcadApplication acApp = new AcadApplicationClass();
           //open for read only
           acApp.Documents.Open(sourcePath, Type.Missing, Type.Missing);
           AcadDocument AcadDoc = acApp.ActiveDocument;
           acApp.Visible = true;
           AcadBlocks blocks = AcadDoc.Blocks;
           // change block name to suit
           string blockName = "PART";
           AcadBlock bl = blocks.Item(blockName);//gets the block definition of input block name
           // copy blockdefinition to array of AcadObject
           AcadObject[] copy = new AcadObject[1];
           copy[0] = (AcadObject)bl;
           // convert array as single object
           object safe = copy as object;
           //open for read write
           acApp.Documents.Open(tempPath, false, Type.Missing);
           // set source document to be active
           AcadDocument newDoc = acApp.ActiveDocument;
           // prepare arguments for CoptObjects
           object IdPairs = new object();
           // set all arguments as objects
           AcadDoc.CopyObjects(safe, newDoc.Blocks as object, ref IdPairs);
           // close and save destination document
           newDoc.SaveAs(tempPath, Type.Missing, Type.Missing);
           acApp.ActiveDocument = AcadDoc;
           newDoc.Close();
           // close source document without changes
           AcadDoc.Close(Type.Missing, Type.Missing);
           acApp.Quit();
~'J'~
alex_b
Message 13 of 14 (362 Views)
09-05-2012 11:37 AM in reply to: Hallex
Hallex
The method you posted adds the block definition to the Blocks collection.
I needed it to work like the WBLOCK Autocad command, so I had to modify it a little for that (copy the block definition entityes to the new db model space).
There were some issues with parameters too (probably because the Acad 2004 compatibility requirement).
Anyway, your suggestion works great and Thank you.
Here is the final code:
private void createOutDwg(string tempPath, string blockToOutput)
  AcadBlocks blocks = aCadDoc.Blocks;
  AcadBlock bl = blocks.Item(blockToOutput);//gets the block definition
  // copy block definition to array of AcadObject
  int i = bl.Count;
  AcadObject[] copy = new AcadObject[i];
  for (int j = 0; j < i; j++)//iterates thru the block definition
    copy[j] = (AcadObject)bl.Item(j); ;//gets one entity
  //create new document
  acApp.Documents.Add(Type.Missing);
  //remember it
  // prepare arguments for CopyObjects
  aCadDoc.CopyObjects(safe, newDoc.ModelSpace as object, ref IdPairs);
  //save and close destination document
  //make source document active before closing new doc
  acApp.ActiveDocument = aCadDoc;
  newDoc.Close(Type.Missing, Type.Missing);
 I still can't understand why we can't just add entities from the block definition to a selection set and the just Wblock() it. Maybe the Autocad people would like to comment on that.
Thank you again.
alex
Hallex
Message 14 of 14 (359 Views)
09-05-2012 11:55 AM in reply to: alex_b
Glad I could help,
Happy coding,
Cheers :smileyhappy:
~'J'~
You are not logged in.
Ask the Community
