.NET
AcadDocument.SaveAs
6 REPLIES 6
3356 Views, 6 Replies
AcadDocument.SaveAs
Hi All,
I have to create a .dwf file and save it programmatically using C#, here's my code regarding this, but it's not working
app = new AcadApplicationClass();
AcadDocument doc = app.ActiveDocument;
doc.SaveAs(@"c:\Sam.dwg",AcSaveAsType.acR15_dwg,new Autodesk.AutoCAD.DatabaseServices.SecurityParameters());
can anyone solve my problem, thank's
Prakash.C
6 REPLIES 6
RonnieWilkins
You do not save as a dwf. You print to the DWF plotter.
Ronnie Wilkins, Jr.
Sorry rwilkins,
by mistake i mentioned as .dwf actually i have to create a .dwg with some basic entities programmatically, that's it, do U have any solution for it....?
Prakash.C
RonnieWilkins
might try not supplying the new security object instead only supply filepath and version info.
Ronnie Wilkins, Jr.
Hi rwilkins,
Now it's working i changed it as
doc.SaveAs("d:\\Sam.dwg",AcSaveAsType.acR15_dwg,new Autodesk.AutoCAD.DatabaseServices.SecurityParameters());
Prakash.C
This was really helpful Prakash. I do get an error with the last parameter:
It states that this is obsolete. I think this may be because I am using AutoCAD 2008. Are there any suggestions?
ronixjdiaz
If you want, you can use only  two  parameters.
doc.SaveAs("d:\\Sam.dwg",AcSaveAsType.acR15_dwg)
In my case I have used it for save my file like a *.dxf
doc.SaveAs("d:\\Sam.dwg",AcSaveAsType.acR15_dxf)
It continues works in Autocad 2013
”Boost
