.NET
*Yannis Makarounis
Message 1 of 2 (108 Views)
AcadApplication
108 Views, 1 Replies
01-07-2007 11:58 AM
I am new to AutoCAD development. I am using C# (VS 2005) and AutoCAD 2007.
I noticed that the following classes AcadPopupMenu> are used in several code snipets that I have found.
AutoDesk.AutoCAD.Interop seems to be required in order to use these, so I
added a reference to AcObjClassImp17.tlb
I assumed that adding and
AutoDesk.AutoCAD.Interop.Common> will make the above classes available but
it does not happen.
Any ideas what am I doing wrong?
Yannis
*Yannis Makarounis
Message 2 of 2 (108 Views)
Re: AcadApplication
01-07-2007 12:07 PM in reply to: *Yannis Makarounis
ok, problem solved.
I should have referenced the AutoCAD 2007 type library.
"Yannis Makarounis" wrote in message
news:5443577@discussion.autodesk.com...
it does not happen.
Yannis
You are not logged in.
Announcements
Need installation help?
Ask the Community
