Hi, ty for you response.
When I use your method, I get a lot of results, but not all. For Example, "ZoomExtents" is not in the return values:
0: Void
1: Void
2: Void
3: Void
4: Void
5: Void
6: Void
7: Void
8: Void
9: Void
10: Void
11: Void
12: Void
13: Void
14: Void
15: Void
16: Void
17: Void
18: Void
19: Void
20: Void
21: Void
22: Void
23: Void
24: Void
25: Void
26: Void
27: Void
28: Void
29: Void
30: Void
31: Void
32: Void
33: Void
34: Void
35: Void
36: Void
37: Void
38: Void
39: Int64
40: String
41: IAcadApplication
42: AcadDatabase
43: Void
44: Void
45: AcadMaterial
46: Void
47: Int32
48: Void
49: Void
50: Void
51: Void
52: Void
53: Void
54: Void
55: Void
56: Void
57: Void
58: Void
59: Void
60: Void
61: Void
62: Void
63: Void
64: Void
65: Void
66: Boolean
67: Void
68: AcadUtility
69: AcadDocument
70: Void
71: Object
72: Void
73: AcadDocument
74: Void
75: Void
76: Void
77: Void
78: Object
79: Void
80: Void
81: Void
82: AcadSelectionSet
83: Boolean
84: Void
85: Void
86: Void
87: AcWindowState
88: Void
89: Int32
90: Void
91: Int32
92: Void
93: AcadLayout
94: AcadMaterials
95: Object
96: AcadPlot
97: AcadLayer
98: Void
99: AcadLineType
100: Void
101: AcadDimStyle
102: Void
103: AcadTextStyle
104: Void
105: AcadUCS
106: Void
107: AcadViewport
108: Void
109: AcadPViewport
110: Void
111: AcActiveSpace
112: Void
113: AcadSelectionSets
114: AcadSelectionSet
115: String
116: String
117: String
118: Boolean
119: Void
120: Boolean
121: Boolean
122: AcadModelSpace
123: AcadPaperSpace
124: AcadBlocks
125: Object
126: AcadGroups
127: AcadDimStyles
128: AcadLayers
129: AcadLineTypes
130: AcadDictionaries
131: AcadRegisteredApplications
132: AcadTextStyles
133: AcadUCSs
134: AcadViews
135: AcadViewports
136: Double
137: Void
138: Double
139: Void
140: Object
141: Void
142: Object
143: Object
144: AcadLayouts
145: AcadPlotConfigurations
146: AcadDatabasePreferences
147: AcadFileDependencies
148: AcadSummaryInfo
149: AcadSectionManager
150: Object
151: Object
152: ObjRef
153: String
154: Boolean
155: Int32
156: Type
Found: 157
Code:
int i = 0;
try
Autodesk.AutoCAD.Interop.AcadApplication AcadApp =
(Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
Autodesk.AutoCAD.Interop.AcadDocument doc = AcadApp.ActiveDocument;
Dictionary<string, string> dict = GetAcadInteropMethods(doc);
Autodesk.AutoCAD.Interop.AcadUtility acutil = doc.Utility;
foreach (KeyValuePair<string,string> kvp in dict)
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n{0}: {1}", i.ToString(), kvp.Value.ToString());
i++;
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nFound: {0}", dict.Count.ToString());
catch (System.Exception Ex)
{ MessageBox.Show("Error testing GetAcadInteropMethods on CADS.Application.AcadApplication: " + Ex.ToString(), "Error", MessageBoxButtons.OK, MessageBoxIcon.Error); }
Thanks.
