.NET
Active Contributor
kylei7449
Message 1 of 2 (124 Views)
AcSmComponents17 1.0 library missing/Code Help
124 Views, 1 Replies
02-08-2013 12:53 PM
I'm not a programmer so my question may seem obvious. I'm trying to run this code and it gives me a library missing error. I changed the reference from 17 to the AcSmComponents18 library. Now it gives me a runtime error "can't create object."  [at the Set sheetSetMgr = New AcSmSheetSetMgr line]
Does anyone know how I can get this code to run in ACAD 2010...thx
' Written by Lee Ambrosius ' Date: 3/24/04
' Program is provided AS-IS with no expressed written warranty
' This example demonstrates a couple of the new SheetSet API and some of its
' many properties and methods
Option Explicit
Dim sheetSetMgr As IAcSmSheetSetMgr
Dim sheetdb As IAcSmDatabase
' Lets count up Sheets and iterate through all open SheetSets
Public Sub SetSheetCount()
Dim sheetCount As Integer
Dim iterDb As IAcSmEnumDatabase
Dim ItemDb As IAcSmPersist
Set iterDb = sheetSetMgr.GetDatabaseEnumerator
Set ItemDb = iterDb.Next
Do While Not ItemDb Is Nothing
Set sheetdb = ItemDb
' Lock Database
LockDatabase
On Error Resume Next
Dim sheet As IAcSmSheet
Dim iter As IAcSmEnumPersist
Dim Item As IAcSmPersist
Set iter = sheetdb.GetEnumerator
Set Item = iter.Next
Do While Not Item Is Nothing
Set sheet = Item
If Item.GetTypeName = "AcSmSheet" Then
sheetCount = sheetCount + 1
End If
Loop
' Apply the Sheet Count as a custom property
Dim cBag As IAcSmCustomPropertyBag
Dim cBagVal As New AcSmCustomPropertyValue
Set cBag = sheetdb.GetSheetSet().GetCustomPropertyBag
cBagVal.InitNew cBag
    cBagVal.SetFlags CUSTOM_SHEETSET_PROP
cBagVal.SetValue CStr(sheetCount)
cBag.SetProperty "Total Sheets", cBagVal
Set cBagVal = Nothing
' Unlock the database
UnlockDatabase
' Clear and check for next SheetSet that is open
sheetCount = 0
Loop
End Sub
' Used to Lock the database back up (SheetSet)
Private Sub LockDatabase()
Dim lockStatus As AcSmLockStatus
Let lockStatus = sheetdb.GetLockStatus
    If lockStatus = AcSmLockStatus_UnLocked Then
sheetdb.LockDb sheetdb
End If
End Sub
' Used to Unlock the database back up (SheetSet)
Private Sub UnlockDatabase()
If lockStatus = AcSmLockStatus_Locked_Local Or AcSmLockStatus_Locked_Remote Then
sheetdb.UnlockDb sheetdb
End If
End Sub
norman.yuan
Message 2 of 2 (111 Views)
Re: AcSmComponents17 1.0 library missing/Code Help
02-08-2013 02:49 PM in reply to: kylei7449
Is your code VBA code or VB.NET API code (since you post in .NET forum)? To me, it looks suspiciously like VBA code.
Also, you mentioned you use AutoCAD 2010, but did not mention it is 32-bit or 64-bit version. If the code is VBA code, 32/64-bit really matters.
That is, if the code is VBA code and you are using 64-bit AutoCAD, the code simply does not work and no way to fix. You need to find other workaround (i.e. use .NET API DLL in conjunction with 64-bit Sheet Manager COM interop).
You are not logged in.
Ask the Community
